Planning - Bridgeport Interact 1 linuxCNC Retrofit
10 years 9 months ago - 10 years 9 months ago #68267 by cncnoob1979
36.90ma to activate the relay.
attached data sheet for DC relay
Your browser does not support embedded PDFs. Please download the file here: Download PDF.
So I can do one relay per axis with these? One for each enable signal per axis that is.
Last edit: 10 years 9 months ago by cncnoob1979.
10 years 9 months ago #68271 by csbrady
I wired my machine using GPIO pins and it works fine. The outputs have plenty of power to drive small relays. I didn't look at how the ENA outputs work and can't tell you if they are directional or not.
10 years 9 months ago - 10 years 9 months ago #68275 by cncnoob1979
Hey great news. I got the enables working on a test. I connected it as I last described from --Todd -and- it's working.
Thanks for every one helping me understand how to make this work!
My next question is :
can I create a jumper coming from field power using the unused pins to connect to the enable + pin? Or do I need to run sourcing power directly from my 24v system to them each individually?
I'm powering the 7i77 field power from the same 24v supply.
Basically I'm wanting to use the VFIELD 3 unused pins as a 24v terminal block, to power my enable switches.
10 years 9 months ago #68278 by Todd Zuercher
cncnoob1979 wrote: Hey great news. I got the enables working on a test. I connected it as I last described from --Todd -and- it's working.
If I understood the question correctly. Yes. I think one of the main reasons for the extra field power connections on the 7i77 is for you to use them for this purpose of routing field power to things like your ENA+ connector.
The following user(s) said Thank You: cncnoob1979
10 years 9 months ago - 10 years 9 months ago #68281 by cncnoob1979
image missing http://i346.photobucket.com/albums/p431/swill008/2015-11/38C016DE-A2B4-480E-9736-A9E869E1494C_zpsialnk5em.jpg
image missing http://i346.photobucket.com/albums/p431/swill008/2015-11/023954BD-05F2-4E32-969A-A65C3E9F43A0_zpsosjq3zkp.jpg
image missing http://i346.photobucket.com/albums/p431/swill008/2015-11/5194C349-ECA6-4150-8C9F-B6681C4AC83F_zpslwh1dfce.jpg
Well after a few hours testing all I need todo now is wire up an encoder from the 702B EXE box.
I was [/-----/ ]this close to cutting an hdmi cable. But I need to just order some cable. I think I'll just grab some CAT6e cable and test it.
Thanks guys, yeah I ask some silly questions sometimes but you help me out anyway!
Getting closer, I have run/stop limits and this is all starting to make sense to me now!
10 years 9 months ago #68283 by csbrady
If you use cat5 or cat6 (no advantage to using cat6 BTW) then you need to give some thought as to which wires to use. Cat5/6 has 8 twisted pairs. For the differential signals use a pair for the plus and minus signals. Pairs are the same color but one wire will be predominantly white. This will be the A, B and Index signals. You will have a number of unused wires so be sure that the unused wires are connected to ground on one end. Not being shielded should not be a problem as long as the run is fairly short.
Time to create page: 1.474 seconds
