TB5 is the 7I77s analog drive interface connector. It has both the +-10V analog
outputs and the drive enable connections. Each drive interface uses 4 pins. TB5 is a 24
pin 3.5 MM pluggable terminal block supplied with six four pin removable screw terminal
plugs.
TB5 PIN SIGNAL DIRECTION
1 ENA0- FROM 7I77
2 ENA0+ FROM 7I77
3 GND FROM 7I77
4 AOUT0 FROM 7I77
ANALOG SERVO DRIVE INTERFACE
The 7I77 provides six channels of +-10V analog servo interface on connector TB5.
Minimum load resistance is 2K Ohms. Normally analog servo drives use differential inputs
to avoid ground loops. Suggested wiring is shielded twisted pair with7I77 AOUTN to drive
AIN+, 7I77 GNDN (adjacent to AOUTN) to drive AIN- as the twisted pair and 7I77 GNDN
connected to the shield at the 7I77 end only. The drives common or GND signal should be
connected to the 7I77 power GND with a separate wire.
SERVO ENABLE OUTPUTS
Six uncommitted OPTO coupler outputs are available for drive enable. Five of these
outputs are (ENA0 through ENA4) are switched in common while ENA5 can be
independently switched for spindle applications. The ENA outputs are floating switches so
can be used for active high and active low drive enables. Output rating of the switches is
50 mA max at 100VDC max . Note that the enable outputs are polarized and can be
damaged with reverse polarity. For active high drive enables, ENAN+ should go to the
appropriate positive power supply and ENAN- to the drive enable input. For active low
enable drives, ENAN+ should go the the drive enable and ENAN- to control power ground.
cncnoob1979 wrote: Can someone explain to me in layman terms how I could connect my Servo AMPS enable to the enable inputs on the 7i77?
My enables are connected to a 24v DC relay.
cncnoob1979 wrote: Thanks for the quick reply. However I did try that, I used my multi-meter and tried to check voltages all I received were milliamps, no real voltage coming from the 7i77
Ill have to check on the voltage requirement in the manual.
