Got off the phone with Mesa Electronics today.
The person I talked with was very helpful, I was concerned with the hold placed on my order since it "fell off", I'm using USAA banking. I'm hoping Ill get my hardware soon .... here is hoping! And I have only been waiting for a short time so far
csbrady,
Yes my 702b have jumpers. I called the manufacture to get the documentation for mine. They were extremely helpful and had my documents within minutes.
I'm contemplating removing the casing from my 601'c and use just the boards stacked up with nylon spacers. However I'm concerned with noise. Ive seen another do it this way and takes up minimal space.
I plan to go with a 3 hp or above for the VFD, I plan to mount it externally. Re-using all the existing hardware as long as it works. When it goes out I will probably upgrade to AC drives/servo's - then rewire. But for now Ive got my fingers crossed.
Also, is there any possible way I could get your configuration folder files and custom panel? I would love to tinker with it while I'm waiting for my Mesa hardware. You wouldn't happen to still have your drawing file for the panels you built as well would you? I planned on doing the same things when I get my mill running. Would save me a lot of time measuring, ect...
Nice breaking resistor setup! I'm going to copy you!
TntSalad,
I was talking about keeping my existing fly-back diodes installed, Im replacing my relays with new ones that already have a fly-back diode installed. I was concerned with having "double" diodes per relay.
