PCW wrote: You can use halmeter to check the encoder operation and scaling
Spindle encoders should be scaled so that 1 spindle turn reads as a feedback position change of 1.00
That is, hm2_7i76e.0.encoder.00.position should advance by 1.00 for each spindle turn
Index can be checked with halcmd (setting the index enable signal) and halmeter
(watching the index enable signal to see the it gets cleared on index detection)
