Emcoturn 120 lathe retrofit
10 years 2 months ago #78782 by LutzTD
Replied by LutzTD on topic Emcoturn 120 lathe retrofit
thats great thanx. Its only for threading I guess so it wont be trying to read it at high rpms anyway. For the home switches the emco has 2 24vdc hall sensors. I assume I just power them and then put the hall sensor output as an input? When I set up the linuxcnc I think I put in for home switches, what would the entry in the HAL file look like and what pins would it assign? Or would I need to chose the pins to assign?
10 years 2 months ago #78783 by LutzTD
here are the lines added by the setup tool. This will be OK for a start if I can figure out the physical pin from the HAL pin. But what I would like to do is set up an output to power the hall sensor when the home search begins, an input to read the result (should be below I think), then turn off the hall sensor the rest of the time.
# --- HOME-X --- net home-x <= hm2_7i76e.0.7i76.0.0.input-00 # --- HOME-Z --- net home-z <= hm2_7i76e.0.7i76.0.0.input-01 ---setup home / limit switch signals--- net home-x => axis.0.home-sw-in net x-neg-limit => axis.0.neg-lim-sw-in net x-pos-limit => axis.0.pos-lim-sw-in # ---setup home / limit switch signals--- net home-z => axis.2.home-sw-in net z-neg-limit => axis.2.neg-lim-sw-in net z-pos-limit => axis.2.pos-lim-sw-in ini HOME_OFFSET = 0.000000 HOME_SEARCH_VEL = 0.050000 HOME_LATCH_VEL = 0.016667 HOME_FINAL_VEL = 0.000000 HOME_USE_INDEX = NO HOME_SEQUENCE = 1
10 years 2 months ago #78784 by LutzTD
I assume its these pins? Sorry I know this is really easy for programmers but its all completely new to me.
10 years 2 months ago #78801 by PCW
Replied by PCW on topic Emcoturn 120 lathe retrofit
Yes, hm2_7i76e.0.7i76.0.0.input-00 is the hal pin that corresponds to TB6 pin 1
10 years 2 months ago #78867 by LutzTD
would it make sense to create a custom m-code to turn on and off the home switches then call these as part of the homing routine?
M110
#!/bin/bash
# file to turn on home switches at output 1
halcmd setp hm2_7i76e.0.7i76.0.0.output-00 True
exit 0
M111
#!/bin/bash
# file to turn off home switches at output 1
halcmd setp hm2_7i76e.0.7i76.0.0.output-00 False
exit 0
10 years 2 months ago #78869 by PCW
Why would you disable the home switches?
Time to create page: 0.495 seconds
