Emcoturn 120 lathe retrofit
10 years 2 months ago #78888 by LutzTD
Replied by LutzTD on topic Emcoturn 120 lathe retrofit
cncbasher wrote: your making this into a a far more complex situation that it needs to be , they are meant to be powered all the time , it makes no difference , this also helps with the internals , that is if a fault does occour your advised of it .
if something is switched off then it cannot communicate , your over thinking problems .
thanx :). I do overthink things, but I listen so I will leave them on.
next is the lube control. I am not sure if it pulses lube on its own time or if I have to time the pulses. I will be out of town the rest of this week so Ill look at it sunday.
thanx again
10 years 2 months ago #78894 by cncbasher
depends on the lube pump fitted , but i have a timer in my hal file to do that , so it's not pumping all the time
i noticed i was running a lot of oil , and realised i needed to add a timer , easy to do in hal
their usually biljur lube pumps that pump all the time power is applied , at a preset volume of oil over time
so simple to run the pump of a relay and timer
10 years 2 months ago - 10 years 2 months ago #78896 by LutzTD
yeah, I have a bijur on the mill, so that powers up when I trun on the mill and gives a shot every so often. Its a little much but for a mill im better with too much then not enough.
On the lathe I believe its a Vogel which pumps when its powered, so it would need to be powered with a timer cycle. If it could be further associated with a counter to count pulses so it could be per so many inches traveled it would be even more deluxe.
I also have a relay with a timer. It just needs a pulse and then I can set the duration of the lube run with the timer. I would prefer to do it in software.
Last edit: 10 years 2 months ago by LutzTD.
9 years 11 months ago #83310 by LutzTD
started working on the z-axis today. not having much luck. I wired the motor per the Wiki for the emcoturn120 retrofit using the berger/lahr steppers and the cotrol per the page here but the motor just pulses when I try to make a manual move. also once the button is released for the manual move it chatters. I am pretty sure I just used the default values for the motor tuning. Anyone have experience with the berger/lahr steppers other than on the wiki? It is incomplete in the setup of the drive as far as switches on the front and linuxcnc setup entries. Ill keep plugging away. I have the pulley info (2:1) and the step info from the motors, but I need to get the ballscrew data then calculate the proper step/distance value for linuxcnc setup.
9 years 11 months ago #83312 by tome
Replied by tome on topic Emcoturn 120 lathe retrofit
I recall having the same problem and ended up needing to wire my motors differently than the wiki (or perhaps I misread the wiki). Anyway, next time I am in the shop and have a moment I will try to look at my wiring diagram and settings. I think I documented what I did but it's been a while...
-Tom
9 years 11 months ago #83313 by LutzTD
awesome thanx. At this point Im guessing I have 3 things wrong. the wires, the stepper settings in the software and Im unsure how to actually move the axis in linuxcnc GUI
Time to create page: 0.482 seconds
