Elumatec SBZ 130/01 retrofit
- tmoeti
4 years 3 months ago - 4 years 3 months ago #247059
by tmoeti
Replied by tmoeti on topic Elumatec SBZ 130/01 retrofit
Good day.
for sending via googledrive.... Thanks.
Last edit: 4 years 3 months ago by tmoeti.
- Thank you received: 7491
4 years 3 months ago #247091
Replied by tommylight on topic Elumatec SBZ 130/01 retrofit
Sending files right now, check your whatsapp.
Enjoy.
P.S.
Delete the e-mail from the post above.
Enjoy.
P.S.
The following user(s) said Thank You: tmoeti
3 years 3 months ago #275245
Lately visited this place and this machine is still working all day long, just working harder cutting 10mm wide slots on 6mm thick metal! Directly drilling with that 10mm end mill!
I am amazed it has not disintegrated by now.
The only thing that failed, several times, is the PC. The rest never had a single issue.
And yeah, they never fixed the toolchager, it has a lot of wear so occasionally fails to lock in place.
At least this one is kept a bit cleaner, they found out the hard way how it is to not have this machine!
Will take some pictures probably tomorrow and update here.
Thank you all who helped with this and other stuff i do.
- pmchetan
- Thank you received: 3
2 years 5 months ago #301652
by pmchetan
Replied by pmchetan on topic Elumatec SBZ 130/01 retrofit
@tommylight Can you upload your full hal files. I need to look how you addressing position and feedback pins to 7i74 board encoder channels. I have been trying very similar build but it uses BISS protocol instead of SSI.
2 years 5 months ago - 2 years 5 months ago #301666
Full config is on the first post.
No idea what pins you are looking for, but there are no 7i74 pins in the hal files, only functions like serial encoders or smart serial.
Edit
If you are looking for wiring pins, see the 7i74 manual, RX and TX pins and their inverted pins, keep in mind in most cases the TX from encoder goes to RX on Mesa 7i74, and so on.
Edit
Last edit: 2 years 5 months ago by tommylight. Reason: more info
The following user(s) said Thank You: pmchetan
- pmchetan
2 years 5 months ago #301742
by pmchetan
Your halfiles were very helpful, thank you
I got my encoders spitting data.
Time to create page: 0.294 seconds
