Elumatec SBZ 130/01 retrofit
2 years 4 months ago #302252 by pmchetan
Replied by pmchetan on topic Elumatec SBZ 130/01 retrofit
How does encoder scaling work?
I have a magnetic linear encoder with 1 micron resolution (native 2mm pole distance with interpolation resulting in 1um resolution). My ball screw pitch is 5mm per revolution, so should my encoder raw count be 5000 pulses per revolution and the encoder scale 5000. The encoder spits some large number which seem to work in increments when I move the readhead but the readings are non sense large number like 254921 or similarly large number.
2 years 4 months ago - 2 years 4 months ago #302253 by PCW
Replied by PCW on topic Elumatec SBZ 130/01 retrofit
The scale should be 5000 if the scale resolution is 1 uM
With a scale of 5000, does the position (not the count) change by
1.000 for each mm of motion?
Other possible issues for add position numbers are wrong BISS setup parameters
or clock/data polarity issues.
Last edit: 2 years 4 months ago by PCW.
2 years 4 months ago #302301 by pmchetan
Yes. For small distances, the readings increase by correct amount. In my case starting point X axis changes from -2366.005 -2365.008 moving 1mm.
When I swap tx+ and tx- the data output is same. swapping rx+ and rx- results in the digital read out showing a constant number.
biss_chan_0=xencoder%26ge
setp hm2_5i25.0.dpll.01.timer-us -200
setp hm2_5i25.0.stepgen.timer-number 1
setp hm2_5i25.0.biss.00.timer-number 1
setp hm2_5i25.0.biss.00.frequency-khz 2000
setp hm2_5i25.0.biss.00.xencoder.scale 5000
#setp hm2_5i25.0.biss.00.xencoder.counts-per-rev 130000
2 years 4 months ago - 2 years 4 months ago #302319 by PCW
What are the readings at the far ends of the scale?
26 bits sounds a bit odd since that's 67 meters in microns...
( There may be some status bits included in the 26 bits that
need to be reflected in the format string )
2 years 4 months ago #302371 by pmchetan
How does 26 bits translate to 67 meters?
The scale is not mounted on to the machine but its on the table and everytime the number shown in axis is different. Sometimes it is -20901 to -20768 and completely different number when placed again.
My encoder is 2D0. I tried biss_chan_0=xencoder%24ge after seeing first couple of bits are zero from the table I've attached but the readout in axis changes very minute decimal places while traversing the whole length of the scale with 24ge string.
2 years 4 months ago #302378 by PCW
2^26 * 1u = 67 meters
if there are 0 bits in the data, they must be accounted for in the format string.
That is, if you still have 26 bits total, the format string must have 26 bits, not 24
some of them being dummy (using the "pad" format string entry) bits and not
part of the position part of the data
Do you have a link to the encoder manual?
Are you sure its Gray coded?
Time to create page: 2.535 seconds
