- Thank you received: 3
Elumatec SBZ 130/01 retrofit
- pmchetan
2 years 4 months ago #302396
by pmchetan
Replied by pmchetan on topic Elumatec SBZ 130/01 retrofit
I think their wording 26 bit binary format means its not gray coded.
RLS LA11:
"biss_chan_0=null%1bcrc%6fwarning%1berror%1bencoder%26e" I saw this in a forum post where a person posted he was using similar renishaw glass scale. Where is the information about the format string? man page for hm2 doesn't go into this much details. Also the string I mentioned above doesn't work for me, but the person in the forum said it his scale is working.
RLS LA11:
- Thank you received: 5334
2 years 4 months ago #302400
Replied by PCW on topic Elumatec SBZ 130/01 retrofit
Yes, your scale uses 34 bits rather than just 26 bits so that string looks closer.
you need 24 bits of (non Gray code) position, 2 pad bits, 1 error and 1 warning bit
and 6 CRC bits
The hostmot2 manual page describes the format string components in the SSI section
and 6 CRC bits
2 years 4 months ago #302473
Judging by the pdf I think this is correct, not sure about the initial null though
"biss_chan_0=null%1bcrc%6fwarning%1berror%1bzero%2uencoder%24e"
(the added "zero" is for the zeros bits in the 26 bit position code"
The following user(s) said Thank You: pmchetan
- azim4411
1 year 9 months ago #320307
by azim4411
Replied by azim4411 on topic Elumatec SBZ 130/01 retrofit
Hi tommylight,
I'm an intern working for a manufacturing company in Dubai. i have been tasked to retrofit the sbz 130 which the company bought from a scrapyard few months ago. Basically I need the schematics of the sbz 130 but I can't find it anywhere online and all attempts to communicate with Elumatec directly had no results. My mentor said I could also try getting the assembly drawing to know the mechanisms but I'm hitting a dead end everywhere online. Is there any way you can help?
Thanks,
azim
Thanks,
azim
- Thank you received: 7491
1 year 8 months ago #320364
Replied by tommylight on topic Elumatec SBZ 130/01 retrofit
No idea, i built a NAS last year, so i can not recal if i moved the files there from the phone.
If i do find them, i will let you know.
The following user(s) said Thank You: azim4411
- azim4411
1 year 8 months ago #321425
by azim4411
Hi tommy, any update?
Time to create page: 1.084 seconds
