Elumatec SBZ 130/01 retrofit
9 years 8 months ago #87437 by tommylight
Replied by tommylight on topic Elumatec SBZ 130/01 retrofit
Here are some pictures taken several days ago. It looks much better now, so i will take some more pictures later.
Regards,
Tom
9 years 8 months ago #88523 by tommylight
Sorry for the late addition, here is how the control panel looks now.
Regards,
Tom
9 years 7 months ago #90396 by tommylight
Wisited there some days ago, machine working perfectly cutting slots on 4mm steel profiles with a 9mm roughing end mill, all day every day. Doing it at 100mm/ minute as i did not dare to push it harder, it was made for aluminium.
Drilling holes easily as the profiles have to be drilled first ( 22 holes ) and then slots cut starting from those holes.
Al in all a success.
8 years 3 days ago #119570 by aluplastvz
Replied by aluplastvz on topic Elumatec SBZ 130/01 retrofit
Pozdrav g Berisa vidim da si radio ovog Elumateka ,ja imam slicnu masinu da radim ali nema rotirajuce alate nego automatsku izmenu alata,kako ste resavali programiranje bocnih burgija za frezovanje cilindra na al profilu nekom skriptom ili neki drugi nacin.Inace imam jednu SBC 130 u ispravnom originalnom stanju.
U kom si gradu ja sam cesto na Kosovu radim dosta masine za staklo kao i za al i pvc stolariju,mozda mozemo nesto saradjivat
Pozdrav
aluplastvz@yahoo.com
Zoran
8 years 2 days ago #119634 by tommylight
@Zoran
There is a dedicated forum thread for other languages:
forum.linuxcnc.org/37-international-linu...ki-serb-and-croatian
Or you can use google translate and write in both languages.
Programiranje reznog alata se vrsi na CAM softweru, Linuxcnc treba da zna samo offsete alata, Linuxcnc je kontroller masine, ne bavi se racunanjem puteva alata.
Ja sam u Peci.
7 years 4 weeks ago #147045 by tommylight
FYI, this machine is still working, not a single issue. It does work 8 to 11 hours a day every day.
Added a test config to the original post, will try to find the finished config and upload it.
The following user(s) said Thank You: bevins
Time to create page: 1.274 seconds
