HURCO BMC-20P retrofit
8 years 9 months ago #105130 by tommylight
Replied by tommylight on topic HURCO BMC-20P retrofit
Hallo Andreas,
As i noted on the other thread, the connectors on the fanuc drive look the same as those on the yaskawa drives i have so chances are they use the same wiring inside. You alse mentioned you have the manuals and schematics, so that makes it a lot easier. The toolchanger is the same, if it is the 16 pocket one.
Anyway you look at it, do not worry, we are here to help, and i might drop by in march or april, have some visiting to do in Austria.
Regards,
Tom
7 years 1 month ago #145558 by DaOne
Replied by DaOne on topic HURCO BMC-20P retrofit
Tommylight, is there any chance you can post your files for this machine configuration? Looks like I am using allot of the same things you are. I also have the manual for that spindle drive as well as the wiring for it on my machine I would be happy to send your way.
7 years 1 month ago #145560 by tommylight
I did post them on another thread, thought i did post them here but noticed yesterday i did not, so i will upload them later in the evening.
7 years 1 month ago #145561 by DaOne
Thank you. I am sure this will be a big help. Did you ever get your spindle drive figured out or did you replace it?
7 years 1 month ago #145564 by tommylight
I had fixed it, it had some input voltage sensing issue.
I did change all the drives to Granite Devices Argon.
7 years 1 month ago #145591 by DaOne
Did you keep the Yaskawa servos? I was told by many that none of the drives would work with these servos. I was gonna replace them with Dyn4 servos and drives. Maybe this would be a better way since the Yaskawa servos use a tapered shaft and the Dyn4 are straight. Means I have to make a coupler.
Time to create page: 0.368 seconds
