HURCO BMC-20P retrofit
6 years 9 months ago #154858 by tommylight
Replied by tommylight on topic HURCO BMC-20P retrofit
I remember using Carousel comp made by Andy for sure, but i do not remember why and how i used remap.
I also recall it having an index pin and a pocket pin ( pin=switch=sensor) and a relay board that controlled the tool changer that after a bit of cleaning and service got to work nicely again after wiring it to 7i77/7i70/7i71.
6 years 8 months ago #156654 by bruno2626
Replied by bruno2626 on topic HURCO BMC-20P retrofit
Hi tommylight,
After adapting your files, the tool change works!
Here are my files:
File Name: Hurco.rar
File Size:56.57 KB
Thanks!
For my wayward spindle drive, I found 3 capacitors on the drive's internal power supply that are dead. I'm going to change all of its capacitors.
6 years 8 months ago #156656 by tommylight
Glad you got it working, it's nice to see old machines brought back to life.
4 years 9 months ago #233607 by smc.collins
Replied by smc.collins on topic HURCO BMC-20P retrofit
Dug from grave
As a soon to be owner of a hurco BMC 20 and a BMC 30, both of which need control retrofits afaik, Please if you can share any information on how you wired, pinned out and programmed these tools changers would be immensely helpful to me. I have a SLV40 in the deal coming as well, but that tool changer is a bit more complex.
4 years 2 months ago #248832 by Jake
Replied by Jake on topic HURCO BMC-20P retrofit
Tommy,
Does your BMC have the 2 speed spindle motor on it ? The one that changes speed from the change in motor windings ?
Thanks!
4 years 2 months ago #248855 by tommylight
Time to create page: 0.436 seconds
