HURCO BMC-20P retrofit
4 years 2 months ago #248857 by Jake
Replied by Jake on topic HURCO BMC-20P retrofit
Thanks!! I need to figure out the electric winding change two speed on my machine
4 years 2 months ago #248862 by smc.collins
Replied by smc.collins on topic HURCO BMC-20P retrofit
what's the spindle controller part number, sounds like your in jog mode, i can get the manual if you need it
4 years 2 months ago #248865 by Jake
Thanks SMC,
I have the manual, it is not in jog mode. My spindle motor and drive has a contactor to change winding configuration when the contactor closes it switches the winding configuration so the motor will run slower. This is only for under 500rpm, I have not dealt with in a a long time as I normally run over 500rpm, there is a project coming in that requires deep boring that will be slow.
4 years 2 months ago #248879 by andypugh
Replied by andypugh on topic HURCO BMC-20P retrofit
This might help (or it might not)
4 years 2 months ago - 4 years 2 months ago #248891 by smc.collins
I am very curious about your spindle now, because AFAIK these use the cimr mt III yasakwa AC servo spindle motor controls, there is a low and high speed contactor for 2 sets of windings, it's towards the bottom of the manual, but that's usually only on the 15kw and up drives AFAICT, I have both, I can check in the morning if you like, both machines are untouched. if you need any pictures of them lmk I can post them for you
wiki.milwaukeemakerspace.org/_media/equi...indle_fvd_manual.pdf
Last edit: 4 years 2 months ago by smc.collins.
4 years 2 months ago #249064 by Jake
This is my spindle drive, 11k VS-626MT III , with the optional 2 motor winding selection.  You can see the winding selection contactor in the lower portion of the picture.
Your browser does not support embedded PDFs. Please download the file here: Download PDF.
Time to create page: 0.509 seconds
