- Thank you received: 338
tommylight wrote: Bob, thank you very much. I think i have them somewhere on my laptop, but since i did not need them till now i am not sure. When i change the failed drive i am going to need them to set up the drive so i will check. I know for sure i have the manual for the spindle drive as i neede to control it manualy to see what is going on.
So the drive has regenerative problems ( A03 ), checked the resistor it is OK, that means that the regenerative rectifier or regenerative transistor inside the drive are faulty. Fixable most probably, not mine so changing the drive and the spindle drive. Not sure but i think i can get the drive for 350 and spindle drive for 1500 euro, will have to check.
Regards,
Tom
bevins wrote: With that said, I have have three AC Servo Motors that go with those drives. 1.8KW AC servo's. I am going to try and use the 8i20 mesa cards for them. I think it will work. I have to ask Andy and Peter, but it should work.
It might be non-trivial to use the Yaskawa motors if they use a proprietary encoder interface.
Another option might be the STMBL which does support (some) Yaskawa absolute encoders:
github.com/rene-dev/stmbl/wiki/conf
But getting an STMBL assembled and in your hands isn't that easy at the moment.
