epoxy granite cnc lathe
4 years 1 week ago #254766 by Masiwood123
Replied by Masiwood123 on topic epoxy granite cnc lathe
Thanks Arvid! It is not necessary for me, but as I installed the touchscreen it seemed interesting to me to try how it works. I will try:)
4 years 1 week ago #254777 by tommylight
Replied by tommylight on topic epoxy granite cnc lathe
If you copy those files there, it will ask to overwrite the existing ones, so the normal Axis GUI will not work anymore, you will be stuck with the version2.
Not very sure about that, but i think that is what happens last time i tried it a few days/weeks back, if i was checking that version.
Still, open a terminal as Arvi said, sudo nautilus or sudo caja or sudo thunar or... depends on what version you are using, so open a file manager and on the help menu choose about, it will show the exact name.
That will open the file manager as superuser so be careful what you do with it, and close it as soon as you finish testing or copying to avoid making a mess! :)
The following user(s) said Thank You: Masiwood123
4 years 1 week ago #254780 by Masiwood123
bolje da se ne igram onda, i onako sam jedva sve namestio da radi, trebalo bi m nedeju dana za opet ,ako se nesto pokvari:)
4 years 1 week ago #254782 by tommylight
Ma jebi ga, poakvari, sredi, tako se uce komplikovane stvari! :)
4 years 1 week ago #254783 by Masiwood123
a i to sto kazes xD..mozda bi resilo ako iskopiram postojece axis foldere negde..pa za slucaj da ovo nije ok da mogu obrnutim smerom da vratim na staro?
4 years 1 week ago #254789 by andypugh
Replied by andypugh on topic epoxy granite cnc lathe
FWIW I know a foundry who charges £10/kg for one-off castings. He cast these lathe parts for me.
photos.app.goo.gl/x4sVA4ZrB96tkCpb8
If you want to see the patterns and finished job: goo.gl/photos//2dwiVYxDTyD9ibti6
(No guarantees on the URL, on train WiFi that doesn't allow photos so URLs hand-typed from my phone)
Time to create page: 0.469 seconds
