epoxy granite cnc lathe
4 years 5 days ago - 4 years 5 days ago #255207 by Masiwood123
Replied by Masiwood123 on topic epoxy granite cnc lathe
I played a little today manually with mpg, with the Chinese carrier the results are good. i'm waiting for multifix, to finish the Y axis and i'm almost done.
Last edit: 4 years 5 days ago by Masiwood123.
The following user(s) said Thank You: arvidb, tommylight
4 years 5 days ago #255214 by tommylight
Replied by tommylight on topic epoxy granite cnc lathe
What, no video?
I am disapointed! :)
Cuts look clean, so no vibration as far as i can see on the pictures, nice.
4 years 5 days ago #255217 by Masiwood123
xD ..video for another day when i play the auto mod;) ,
I will quickly draw a chess figure and document it, since everything is around the knife holder
all a bit weak'' even the holder accepts only 12x12 mm, i am satisfied with the processing ,and that by hand.
4 years 2 days ago - 4 years 1 day ago #255513 by Masiwood123
out of the title, Tomo, wanted this for some small five axis(for xy) for small figures, for now it stands, does the stone engraving machine you are making have a classic z axis? is that the construction is not so strong, but the quality is top (less wind turns the ballscrew:)
Last edit: 4 years 1 day ago by Masiwood123.
4 years 1 day ago #255526 by tommylight
What did i do now? :)
does the stone engraving machine you are making have a z axis? is that the construction is not so strong, but the quality is top (less wind turns the ballscrew:)
Yes, the bigger ones have a Z axis, small ones do not, they use a small 3 phase servo motor to put pressure of about 1KG to 2KG on the spinning bit.
Big ones do about 2KG to 4KG.
The following user(s) said Thank You: Masiwood123
4 years 1 day ago #255552 by Masiwood123
if you manage to find some transport, it's yours.. i have always been interested in how these machines work, but i have no need to make them
Time to create page: 0.176 seconds
