epoxy granite cnc lathe
3 years 11 months ago #256150 by andypugh
Replied by andypugh on topic epoxy granite cnc lathe
Or maybe www.eiemaskin.se/produkter/maskinskydd/ who seem to have the Arnold catalogues on their web site.
The following user(s) said Thank You: arvidb, Masiwood123
3 years 11 months ago - 3 years 11 months ago #256261 by arvidb
Replied by arvidb on topic epoxy granite cnc lathe
www.arno-arnold.de/de/
Nice! They have a pretty interesting catalogue , showing different end connections and guides.
I'm pretty sure EIE sells to companies only (probably a better chance of being able to buy directly from Arno Arnold!), but thanks for the tip! It's absolutely worth checking them out.
Last edit: 3 years 11 months ago by arvidb.
3 years 11 months ago #256309 by andypugh
Three hours of wobble?
Seriously, what are the units of the indicator?
Is it completely true at the chuck? 3-jaws are rarely exactly centred.
3 years 11 months ago - 3 years 11 months ago #256311 by Masiwood123
Replied by Masiwood123 on topic epoxy granite cnc lathe
I'm trying to get the tailstock in the center with the headstock, this is only rough right now, I have to get a better indicator holder because this one doesn't hold the magnet. fi30 adapter to mt3 will go in the tailstock. I certainly checked the headstock (some Chinese version k12 also with mt3 adapter) the accuracy indicator is 0.01, I mean 1mm for full circle, and now it shows on the headstock chuck and in the middle and end of this rod 0.2-0.25mm, which is satisfactory for woodworking, but I will try to improve head chuck on the spot, to reduce the deviation
Last edit: 3 years 11 months ago by Masiwood123.
3 years 11 months ago #256315 by andypugh
Put the indicator on the spindle and clock the tailstock bore.
That way you take the chuck and the test rod out of the equation. (even if the chuck is eccentric and the spindle is bent).
The spindle rotational axis is always a straight line unless things are very wrong (like egg-shaped bearing balls or variable-thickness inner bearing rings.
The following user(s) said Thank You: Masiwood123
Time to create page: 0.439 seconds
