epoxy granite cnc lathe
3 years 11 months ago #256843 by Masiwood123
Replied by Masiwood123 on topic epoxy granite cnc lathe
I am currently in the phase of making two configurations, one for lathe mode where z will be the long axis and x will be transverse, and I need another where the names of the axes will change places, because on the transverse support I have motors that will to process wood, and the cam program I use for that always considers the Z axis as a mill and I can't modify the postprocessor.
3 years 11 months ago - 3 years 11 months ago #256955 by Masiwood123
today I gave birth to a bear..since I combined two operations in gcode, the first one that makes a hole like g17 and the second one that makes an outer contour (put in gcode G7)..however linux sees both operations as g7 so it doesn't make a round hole for me but an ellipse , divide x by 2. Is there a way to make the first operation (see the hole normally, and in the following line to read the lathe operation, with G7) not worth doing separate operations, but would like to place everything in one file? thanks
youtube.com/shorts/w0sIjqA-jdU
Last edit: 3 years 11 months ago by Masiwood123.
3 years 11 months ago #256993 by andypugh
Replied by andypugh on topic epoxy granite cnc lathe
Just put a G8 in the code before the hole and a G7 after?
It's a very nice ellipse though, Why not see it as a Bob Ross happy accident?
The following user(s) said Thank You: Masiwood123
3 years 11 months ago #257040 by Masiwood123
The G8 does the job, it's a round hole now, thank you very much. Yes, I like the ellipse, maybe I'll make it for my friends, but the client is asking for a round one, to fit more alcohol:)).. but I'll have to do it in two separate operations, it's too thin and the processing is bad.. today I successfully made a small adapter for the tailstock that will hold when I do the outer contour..to be continued..
3 years 11 months ago - 3 years 11 months ago #257348 by Masiwood123
except for some small things, the job is done, thank you all for your endless help, cheers!
3 years 11 months ago #257357 by tommylight
Replied by tommylight on topic epoxy granite cnc lathe
Nicely done, maestro. :)
Where is "rakia" to fill the glass ... wood ? :)
Time to create page: 0.076 seconds
