epoxy granite cnc lathe
3 years 11 months ago - 3 years 11 months ago #256331 by Masiwood123
Replied by Masiwood123 on topic epoxy granite cnc lathe
thanks for the good advice, in that case i should use this type of clock?
www.hahn-kolb.net/Sve-kategorije/Kompara...5521.cgid/sr/RS/EUR/
Last edit: 3 years 11 months ago by Masiwood123.
3 years 11 months ago #256363 by andypugh
Replied by andypugh on topic epoxy granite cnc lathe
Clocking round the outside of a bar held in the tailstock (with your existing indicator) will work too. It's probably not worth buying a lever style gauge just for this.
3 years 11 months ago #256368 by Masiwood123
ok, it didn't occur to me then, in the moment, that I can turn the existing indicator at an angle even though the pin is fixed:) thanks, I'll try
3 years 11 months ago #256377 by andypugh
I might not have explained very well, so here is a very poor quality video.
youtube.com/shorts/Vk4iNr4DojM?feature=share
There is too much stuff in the way on my lathe, but this setup checks that the tailstock is aligned with the actual axis of rotation of the headstock.
The following user(s) said Thank You: Masiwood123
3 years 11 months ago #256378 by Masiwood123
I understood it so that i remove this rod that holds the magnetic cube from the magnet,
and clamp it in the chuck, and then spin it around the entire bar held of the tailstock, 360°
3 years 11 months ago #256379 by Masiwood123
your holder model has a conical shank, so i'm guessing that's why you didn't clamp it in the headstock chuck
Time to create page: 0.349 seconds
