epoxy granite cnc lathe
4 years 1 week ago #254792 by Masiwood123
Replied by Masiwood123 on topic epoxy granite cnc lathe
this looks great! and it's great say for the headstock in my case, because I didn't make it the best, but I'll see in practice.. (unfortunately, I can't open this second link). Do you draw a 3d model in Cad (positive or negative) and they do it, or do you draw a mold for them? Is it in UK or ? Tom and I are far from you, although I think there is a foundry near me, so I could ask..
4 years 1 week ago - 4 years 1 week ago #254797 by Masiwood123
this works and I like it :) only for some reason the sliders cover the spindle dro, maybe I should try a different monitor resolution?
Tomo, when I return the ini to display -axis..it starts the normal axis configuration, regardless of the fact that the files are overwritten, so that's great too.
Last edit: 4 years 1 week ago by Masiwood123.
4 years 1 week ago #254811 by andypugh
Replied by andypugh on topic epoxy granite cnc lathe
The second link should have been goo.gl/photos/2dwiVYxDTyD9ibti6
Typically I design the part, then make a copy 2% bigger to allow for shrinkage, then add on the casting draft (and any core prints) That becomes the main pattern. Then core boxes and "odd sides" and other similar things are made by subtracting the main pattern from solids.
It's a fun exercise, designing patterns, but the simplest pattern is just a slightly over-sized and plus-matarial version of the part you want.
The following user(s) said Thank You: Masiwood123
4 years 1 week ago #254816 by tommylight
Replied by tommylight on topic epoxy granite cnc lathe
Set the font to something smaller, it should fit ok.
Nice, i am glad it does work with both Axis! :)
4 years 1 week ago #254836 by Masiwood123
I looked at the pictures, it's amazing the dedication to work without exception to make everything right, I especially like the part with the wood, because I'm a carpenter, I've rarely seen someone work wood on a metal milling machine, that part is very interesting to me. as far as drawing is concerned, I could draw what I imagine in Solidworks (I use it the most), the problem is that there are no foundry in our area who would put it into practice... also, since I primarily work with wood, I always needed a smaller milling machine to make some metal parts for machines, I think I will bid on this one www.surplex.com/en/m/elcons-numerical-co...-machine-682228.html , seems easy to retrofit and takes up little space. Otherwise, I have a metal lathe, but my old father won't allow me to convert it into cnc, because he wouldn't know how to use it:)
4 years 1 week ago #254839 by Masiwood123
Time to create page: 0.189 seconds
