epoxy granite cnc lathe
4 years 1 week ago #254717 by tommylight
Replied by tommylight on topic epoxy granite cnc lathe
sudo apt-get install onboard
Then on the "accessories" menu.
Has plenty of stuff to configure, like transparency, size, type, start at boot, etc.
The following user(s) said Thank You: Masiwood123
4 years 1 week ago #254720 by Masiwood123
Replied by Masiwood123 on topic epoxy granite cnc lathe
ooo thank y! google doesn't know, I've been searching for half an hour without success, I was already falling asleep, tomorrow I will continue with the game:)
4 years 1 week ago #254760 by Masiwood123
question:)
how to change  permission of user folder, i cant paste any file here??
4 years 1 week ago #254763 by arvidb
Replied by arvidb on topic epoxy granite cnc lathe
You don't want to change permissions of the /usr folder, it's meant to be owned by and managed by root. It's very unusual to have to paste files there. What is it that you are trying to do?
4 years 1 week ago #254764 by Masiwood123
I'm trying to load axis2 by zack..it says to copy  content to user/share/images...or axis folder.. but I think I can't because I don't have permission on the folder.
forum.linuxcnc.org/21-axis/40659-axis-2-...iend?start=30#252748
4 years 1 week ago #254765 by arvidb
That's a bit... hacky, but for testing I guess it works! :)
Use sudo then to temporarily give yourself the necessary permissions. Either cp/mv the files directly using the terminal, or start a file manager using sudo (I think the command would be 'sudo nautilus' in Ubuntu) if you want the GUI experience. :)
Time to create page: 0.114 seconds
