epoxy granite cnc lathe
4 years 1 month ago #251141 by Masiwood123
Replied by Masiwood123 on topic epoxy granite cnc lathe
Little update today, 50%done.
4 years 1 month ago - 4 years 1 month ago #251142 by Masiwood123
Last edit: 4 years 1 month ago by Masiwood123.
4 years 1 month ago #251633 by Masiwood123
Y axis construction today..
4 years 1 month ago - 4 years 1 month ago #251637 by Masiwood123
4 years 1 month ago #251644 by Bari
Replied by Bari on topic epoxy granite cnc lathe
The perfectionist in me is screaming "Beef up the X-axis"!
The following user(s) said Thank You: Masiwood123
4 years 1 month ago #251650 by Masiwood123
I agree i should put stronger X but I thought I wouldn't work with metal. The plan is to have two machining motors on the y axis, one with a saw and one with a router bit, on the opposite side there will be a heavy classic knife holder to balance it. on X Axis .Tailstock should be Z axis..I am planning this lathe for making some smaller pieces of wood and primarily the main spindle as the A axis, I have to figure out how to connect it so that it can also work as a spindle (S command to main main motor, instead of A) because the piece needs to be cut at the end with a classic knife.
Time to create page: 0.294 seconds
