EMC and 7i43
09 Jul 2011 06:51 #11294 by efinkg
EMC and 7i43 was created by efinkg
I am trying to get a new 7i43 board to connect to EMC2, however I seem to be unable to get the FPGA to load on the board.
I believe I have the jumpers set correctly:
W1 Up
W2 Up
W3 Down
W4 Down
W5 Down
W6 Up
I have ensured in BIOS that my parallel port has an address of 0378, and is running EPP, and I have the 7i43 firmware installed.
Any ideas how to proceed?
I am a little worried that maybe my parallel cable is too long, I have a 15 foot long ribbon cable with ends as provided by Mesa, and the power LED lights up, but nothing else.
09 Jul 2011 07:50 #11295 by cncbasher
Replied by cncbasher on topic Re:EMC and 7i43
change W2 to down
change W3 to up
give it a try , 15' cable should be ok
although i would use a screened cable , rather than ribbon at that length , screened cables tend to be thicker cored than ribbon ,
so less of a voltage drop .
what error are you getting can you post dmesg output
check the bit file exists and correct name and location also
some pc's have EPP & ECP dual mode , make sure it's EPP only
09 Jul 2011 12:56 #11302 by andypugh
Replied by andypugh on topic Re:EMC and 7i43
What is your loadrt hal_parport line?
I think it might need to be :
loadrt hal_parport cfg="0x378"
because the address is in Hex or, to use the auto-detected address:
loadrt hal_parport cfg="0"
09 Jul 2011 13:54 - 09 Jul 2011 13:55 #11303 by PCW
Replied by PCW on topic Re:EMC and 7i43
Do you have 5V power supplied to the 7I43s P1 terminal block? (preferably from the PC that connects to the 7I43)
When jumpered for EPP mode, the three LEDs on the bottom (one yellow and two red LEDs) should be illuminated when first powered up. If you don't get this you likely have a power problem...
Last edit: 09 Jul 2011 13:55 by PCW.
09 Jul 2011 19:28 #11316 by efinkg
Replied by efinkg on topic Re:EMC and 7i43
So I need an external power supply in addition to the parallel cable?
09 Jul 2011 20:10 #11318 by efinkg
Thanks, that solved it!
09 Jul 2011 20:17 #11319 by cncbasher
how are you supplying 5v to the 7I43 to P1 ? , the 7i43 requires a 5v dc supply
09 Jul 2011 20:19 #11320 by efinkg
Off one of the PSU plugs.
09 Jul 2011 22:42 #11329 by efinkg
After being able to connect to the 7i43 through the standard config, I tried setting up a file using PNCConf and am able to connect to the 7i43, but I get an error "HAL: ERROR: duplicate variable '.in'" and everything disconnects.
I'm very new to linux and I suspect I may be missing something basic.
09 Jul 2011 22:55 #11330 by BigJohnT
Replied by BigJohnT on topic Re:EMC and 7i43
Have you tried the 7i43 sample config?
