EMC and 7i43
11 Jul 2011 14:05 #11403
Replied by andypugh on topic Re:EMC and 7i43
PCW wrote:
Probably easily managed with a few op-amps (or off-the-shelf current loop interface chips). But that is getting complicated .
The 7I33 will not drive 20 mA loads at least not on all outputs simultaneously. Its designed to drive
analog +-10V inputs
11 Jul 2011 16:43 #11422
Replied by PCW on topic Re:EMC and 7i43
I'm with cncbasher, the model number of the drives would help a lot here. Otherwise we are playing connection roulette, and are likely to lose...
12 Jul 2011 06:01 #11445
by efinkg
Replied by efinkg on topic Re:EMC and 7i43
I'm working on a Hurco KM3 with randtronics servo amps and electrocraft e26-2 DC servo motors.
I know that all parts were working before the retrofit began.
12 Jul 2011 07:02 - 12 Jul 2011 07:10 #11449
by cncbasher
Replied by cncbasher on topic Re:EMC and 7i43
Randtronics was acquired by CMC Controls. A lot of their data is freely available at their website.
www.burny.com/burny_servomate.asp
i'd recon if you look the part number of the drive will begin something like ' SM1 150-1120 ABC
the SM1 being the board type , 150 being the drive voltage
also more information is in the wiki
wiki.linuxcnc.org/emcinfo.pl?Servomate
so it would appear you could have +- 10v analog drives ,
Last edit: 12 Jul 2011 07:10 by cncbasher.
12 Jul 2011 10:18 #11452
Bear in mind that that Wiki page is old, and refers to problems with index homing in 2.1, and a workaround in 2.2. we are now at 2.4, with 2.5 waiting in the wings and many of us using 2,6, and index homing now "just works"
13 Jul 2011 04:33 #11487
by efinkg
I have 90VDC boards of a style SM1090-1110C or SM1090-11100
I can't quite read the last digit.
13 Jul 2011 08:05 #11488
by cncbasher
ok you have SM1 Boards 90v buss
sm1 manual is available on the previous links but iv'e linked again here
www.skullworks.net/include/Servomate-AO-73187.pdf
supplying analog servo signal from EMC to J4 aux
and analog servo ground to J4 com should do the trick
the aux input pot on the board may need adjusting to give full range of speed
13 Jul 2011 19:50 #11500
by efinkg
My AOut pin appears to be outputting in the mV range, should I try a 5v aux input?
14 Jul 2011 03:42 #11511
Can you try the outputs with nothing connected to the 7I33
~0 output voltage is expected if either the channel is not enabled (check the enable out signal)
or there PWM value is set to 0 or close to 0
Are all three LEDS on on the 7I33?
Are the enable outputs of the 7I33 high (~5V)
What is setting you PWM value (PID?)
Can you unlink the pwm enable and pwm value pins in the HAL file and try setting them by hand?
This will test the hardware. Setting the pwm value (something like hm2_7i43.0.pwmgen.00.value) to the pwm scale should give you 10V, setting pwm value to -pwm scale should give you -10V on AOUT
14 Jul 2011 04:33 #11512
by efinkg
I get a good enable signal, my PID settings are P:1 and all else 0 at the moment. I'm trying to setup a HAL with self-selected PWM commands.
Time to create page: 0.098 seconds
