EMC and 7i43
After being able to connect to the 7i43 through the standard config, I tried setting up a file using PNCConf and am able to connect to the 7i43, but I get an error "HAL: ERROR: duplicate variable '.in'" and everything disconnects.
I'm very new to linux and I suspect I may be missing something basic.
That's a problem with the HAL file. I suspect possibly a space somewhere before a .in in a pin name or similar.
Attach your HAL file to a post and we can have a fossick through it.
Does the error give you a file and line number hint? I didn't see anything in your config that was out of whack.
Type "dmesg" at the command prompt, and then copy-paste it.I would try and post the error file but I've been unable to get it to copy.
You can do dmesg > error.txt and the output is sent to a text file that you can attach.
