Went to 2.5 and now I get 'exceeds maximum' errors
02 Aug 2011 13:20 #12126
Replied by andypugh on topic Re:Went to 2.5 and now I get 'exceeds maximum' errors
We are homing in on this. It seems that the error is raised by the graphical preview, not the trajectory planner, which is why the actual parts come out OK.
This commit
git.linuxcnc.org/gitweb?p=emc2.git;a=com...a0405aafd4bbc5aa36dc
Moved the extents checking out of glcanon.py into gcodemodule.cc, possibly imperfectly.
This commit
- photomankc
- Thank you received: 4
02 Aug 2011 16:26 #12128
by photomankc
Replied by photomankc on topic Re:Went to 2.5 and now I get 'exceeds maximum' errors
Cool, glad you guys are looking at it. My days of being a 'programmer' are behind me. I remember just enough to really screw up anything I look at sideways in C or C++
03 Aug 2011 01:14 #12144
I think I have found it, and I have submitted a patch to the devs. Hopefully you should be able to update soon, and make the problem go away.
- photomankc
03 Aug 2011 13:27 #12154
by photomankc
Andy that's awesome. I'll try to pull an update this weekend and report back on it.
Thanks for taking the time to look at that!
03 Aug 2011 13:28 #12155
by BigJohnT
Replied by BigJohnT on topic Re:Went to 2.5 and now I get 'exceeds maximum' errors
Wait till the patch is pushed before you pull...
03 Aug 2011 13:54 #12157
As JT said, there is no way to tell if or when the patch will be accepted. Best wait until it has been.
You could watch:
git.linuxcnc.org/gitweb?p=emc2.git;a=sho...fs/heads/v2.5_branch
To see if it gets pushed.
You could watch:
- photomankc
04 Aug 2011 13:48 #12183
by photomankc
Ok, will do.
08 Aug 2011 00:00 #12293
by mhaberler
Replied by mhaberler on topic Re:Went to 2.5 and now I get 'exceeds maximum' errors
I just pushed Andy's fix to master:
git.linuxcnc.org/gitweb?p=emc2.git;a=com...590a69b5bce9e31a0ae1
- Michael
- Michael
- photomankc
11 Aug 2011 19:15 #12436
by photomankc
Is there a way to tell if this is now in the build that apt-get will pull? At present I'm not showing any new version to pull down and haven't for several days. I don't know how to tell what the current build number is and if this is in it.
11 Aug 2011 21:31 #12437
by BigJohnT
If your using the installed 2.4.anything it won't be there unless someone cherry picks it from master and then a bug fix will have to released and I've not seen one of those in a long time.
The upshot is you would at this point have to use master by downloading it using git and creating a RIP as shown here . I don't think that there is even a deb built of master although I know one is built for 2.5 by the buildbot.
Time to create page: 0.105 seconds
