LinuxCnc with Copley controls-Stepnet ST3-055-04?
- Thank you received: 4966
07 Feb 2013 05:46 #29738
I can't see the drive having any problems with the motors, but I can definitely see the motors having a problem with the drive, though it does say that the minimum current is zero amps. You would want to make sure that you had the correct current-set resistor, and there are probably many much smaller and cheaper drives capable of running your motors.
Replied by andypugh on topic LinuxCnc with Copley controls-Stepnet ST3-055-04?
I was looking into the Gecko Drive - www.geckodrive.com/geckodrive-step-motor-drives/g540.html
Will this controller have any problems with Nema 8 stepper motors since the stage has Nema 8 stepper motors?
The following user(s) said Thank You: varun0421
- varun0421
07 Feb 2013 06:04 #29739
by varun0421
Replied by varun0421 on topic LinuxCnc with Copley controls-Stepnet ST3-055-04?
"You would want to make sure that you had the correct current-set resistor"
I have a variable DC power supply from which has a range of 10-30 V DC and 0-3 amps. Will this fix the problem?
Also can you please suggest a few controllers which can drive the Nema 8 motors?
Thank You
Thank You
07 Feb 2013 17:08 #29755
No, you need to set the drive to the right current for the motors. That also requires knowing what the right current for the motors is...[/quote]"You would want to make sure that you had the correct current-set resistor"
I am no expert on the subject, but www.pololu.com/catalog/product/2131 might be appropriate.Also can you please suggest a few controllers which can drive the Nema 8 motors?
Time to create page: 0.198 seconds
