LinuxCnc with Copley controls-Stepnet ST3-055-04?
- BigJohnT
- Thank you received: 1177
- varun0421
I currently use a ISP200 - 4 power supply to run a XYZ system with stepper motors. The copley controls stepper motor driver ST3-3 axis is powered by the ISP200.
The specification for the power supply is here - servosystems.com/ims_suppl_isp200.pdf
Will this power supply work with the new controller?
The new controller - www.ebay.com/itm/270549461424?ssPageName...id=p3984.m1423.l2649
Varun
- Thank you received: 5017
Can you adjust the voltage down slightly? 38V is out of range for the TB6560. And they are not the most overload-tolerant of devices.
The datasheet is here: www.toshiba.com/taec/components2/Datasheet_Sync/382/27885.pdf
And that says that the max is 34V (Absolute max is 40V, but I don't think you would get away with that for long)
- varun0421
"Can you adjust the voltage down slightly? "
I am not sure on how to do that. I will try to find out and see if that can be done.
Also i was looking for a data cable to act as a liaison between the stage( Linear actuator) and the controller.
The stage currently has a DB15M(HD) end connector whose pin outs i have.
I was trying SAB cables as an option. Are there any other cable companies which can do this job?
It isn't necessarily possible, but there is a trimmer visible on the board.Can you adjust the voltage down slightly? "
I am not sure on how to do that. I will try to find out and see if that can be done.I tend to make up my own, though it can be a tedious process.I was trying SAB cables as an option. Are there any other cable companies which can do this job?
This took a good hour last night: picasaweb.google.com/lh/photo/CS4ndFKtER...pFm0?feat=directlink
I have a large collection of crimping tools, heat-shrink and a good soldering iron though. Tooling up from scratch would certainly cost more than a commercially-made cable.
- varun0421
I had one quick question - I have attached the pinout for the DB15 male connector.
As it says pins 1-4 are the ones which have the motor outputs in them.
Is it necessary to solder the other pins also since i will be connecting only the motor outputs to the controller/driver?
- varun0421
What would be the safest way to select the dip settings for the first run?
Thank you.
Set the current to suit the motors.
- varun0421
I was looking into buying a more reliable controller since the one that i have is pretty sub-standard.
I was looking into the Gecko Drive - www.geckodrive.com/geckodrive-step-motor-drives/g540.html
Will this controller have any problems with Nema 8 stepper motors since the stage has Nema 8 stepper motors?
Also are there any other stepper motor controllers which are compatible with Nema 8 stepper motors?
