Plasma cutting with servo System in LinuxCNC
- diegoroman17
I need your help already. I want to design a plasma cutting machine with linuxCNC in the core of the system. The mechanics parts are very big and I think that it need design a servo system with AC servo Motors. now I don“t know how begin this task. What drivers I have choose?What AC servo motor I have choose? How I can control the plasma? What cards I need for control?
- BigJohnT
- Thank you received: 1176
- diegoroman17
Can you explain me more about your system touch off and micro switch? Can you show me any picture? I have begun to calculate the mass.I built a floating torch holder with a micro switch to "touch off" on the material top.
- BigJohnT
A couple of photos here
gnipsel.com/shop/plasma/plasma-gallery.xhtml
and more here
s47.beta.photobucket.com/user/johnplctec...rary/Plasma%20Cutter
- diegoroman17
(#1 pierce height, #2 pierce delay, #3 cut height)
Ok, thank you. I have saw your pictures and your O sub for touch off. Only I dont understand how it work with respect to #1 #2 #3 variables? That values are this? can you explain me please?
- BigJohnT
linuxcnc.org/docs/html/gcode/o-code.html#_calling_files
- diegoroman17
- BigJohnT
pierce height is how high the tip should be when the arc is fired
pierce delay is how long to wait before starting the cut
cut height is cut height
All those will be in the cut charts for your torch.
- diegoroman17
- diegoroman17
