Plasma cutting with servo System in LinuxCNC
19 Oct 2012 22:21 #25464 by PCW
Some plasma power supplies provide a 0-10V output to monitor plasma voltage.
If you supply does that, then the THCAD-10 is appropriate
If your plasma power supply does not provide a voltage monitor point,
so all the is accessible is the direct plasma voltage, the THCAD-300 is appropriate
20 Oct 2012 15:32 #25486 by diegoroman17
Replied by diegoroman17 on topic Re:Plasma cutting with servo System in LinuxCNC
can you give me any supplier of plasma supply to my application? I need buy it.
20 Oct 2012 17:57 #25494 by BigJohnT
Hypertherm is a known good maker of plasma torches and have machine torches that fit the smaller units.
20 Oct 2012 20:26 #25502 by diegoroman17
Ok. I have revised powermax 45 and I think that this is the plasma :)
Now this plasma has a input to remote run. It is a open contact. I think that it need close to run the plasma. I check touchoff.ngc file and I think that with
M3 S1 you turn on the plama but how you connect the 7i77 for this?Exist any output that can be a switch? Can you explain me a few how connect the hardware? Thanks
20 Oct 2012 20:43 #25503 by BigJohnT
The M3 turns on the spindle if the Speed is >0 therefor I put the S1. You just pick an output and connect the motion spindle on bit to the 7i77 pin in your hal file.
This is the line from my plasma cutter using a 7i76 card as it is stepper driven.
net spindle-on motion.spindle-on => hm2_5i25.0.7i76.0.0.output-00
21 Oct 2012 00:36 #25521 by diegoroman17
Ok, but powermax 45 need a output of relay not a logic output. My question is if exist any manner of obtain a output of switch in 7i77 or I need drive a external relay for this.
21 Oct 2012 00:44 #25522 by PCW
what is the signal thats switched?
current and voltage?
AC or DC?
21 Oct 2012 00:58 #25523 by diegoroman17
I think that I expressed bad.
The powermax 45 have a input signal for RUN THE PLASMA. this signal is a open contact of two terminals. If you close this contact Turn On the plasma. This action normally is effected with a switch, relay or any mechanical device. Now I want know if this action may be performed with the 7i77 or I need a external relay to join the two terminals of open contact for RUN of plasma.
21 Oct 2012 01:04 #25525 by PCW
only way to know is to know what signal is
switched when you close the contact:
AC or DC?
21 Oct 2012 01:35 #25526 by diegoroman17
I don't know. In the data sheet only say:
Signal:
Start (starting plasma)
Type:
Input
Notes:
Normally open.
Open circuit voltage: 18 VDC at terminals START.
Requires contact closure to activate.
Time to create page: 0.080 seconds
