Plasma cutting with servo System in LinuxCNC
- diegoroman17
27 Oct 2012 07:36 #25865
by diegoroman17
Replied by diegoroman17 on topic Re:Plasma cutting with servo System in LinuxCNC
Sorry, I have a error. not 85 kg. Is 150 kg (330 pounds)
- Thank you received: 5214
27 Oct 2012 22:57 #25891
Replied by PCW on topic Re:Plasma cutting with servo System in LinuxCNC
wow thats heavy! thats ~1000 lbs of force to accelerate at 3 Gs
with 900 oz-in and 3000 RPM you would need about .2" / turn
gearing to get that force meaning top speed would be about 10 IPS
and the motor would have to accelerate to full speed (3000 RPM)
in about 25 mS (120,000 RPM/sec)
This is tough for bare unloaded motors
Not practical without larger motors or less acceleration
- jmelson
- Thank you received: 158
28 Oct 2012 04:14 - 28 Oct 2012 04:17 #25910
by jmelson
Replied by jmelson on topic Re:Plasma cutting with servo System in LinuxCNC
Peter,
I think you dropped a decimal place somewhere. 3000 RPM x 0.2" = 600 IPM,
so he could gear it down some more. (Edit: Oops, 10 IPS = 600 IPM, you
are right on the velocity.) When increasing the reduction ratio,
at some point the motor inertia becomes dominant, you want to keep the ratio
below that.
Assuming 900 oz-in is the peak motor rating, then you have 56.25 Lb-inches
for acceleration. Assuming a .2"/turn ratio, that gives a linear force of
1769 Lbs. So, I don't see a problem, here. he'll get plenty of velocity
and more than sufficient linear force to get his 3 G acceleration.
(The conversion factor for a 5 TPI leadscrew, which gives 0.2" advance
per turn is one I know almost by heart. torque in inch-Lbs / 0.0318 =
linear force in Lbs. The 0.2" advance is the same as an infinitely thin
cord wrapped around a drum of 0.0318" radius.)
Jon
below that.
Jon
Last edit: 28 Oct 2012 04:17 by jmelson.
28 Oct 2012 05:29 - 28 Oct 2012 05:29 #25912
Yes I did it in my head and dropped a factor of 2, but
0 to 3000 RPM in 25 mS is still going to be tough
(and lead screws are out of the question)
Last edit: 28 Oct 2012 05:29 by PCW.
- diegoroman17
28 Oct 2012 09:34 #25916
by diegoroman17
Then in this system result better to use lead screw? How this can better my system? And band transmission is not possible? How I can to dimension the transmission ration to reach the speed and acceleration with a reasonable cost in servo motors and mechanical system?
- jmelson
28 Oct 2012 09:38 #25917
by jmelson
go, that is typical on a router, anyway. I wonder why this
gantry is so heavy, most similar machines are maybe half the
weight. It may be necessary to go with a lower reduction ratio
to keep the motor speed down, as that may already be the
dominant inertia. At least he isn't trying to do this with a
stepper motor!
Jon
Yup, either rack and pinion or belt drive would be the way toYes I did it in my head and dropped a factor of 2, but
stepper motor!
Jon
- diegoroman17
28 Oct 2012 20:48 #25940
by diegoroman17
You have reason. My design is very heavy. I have seen belt drive in quilting machines with gantry mass of aprox 900 pounds with servo motors panasonic of 1KW without lead screw and this works perfectly. How I can down the weight of my design without use aluminum?
Jeje. It is not possible with steppers, just looking at speed torque curve can tell that it is not possible
At least he isn't trying to do this with a stepper motor!
- diegoroman17
30 Oct 2012 22:21 #26070
by diegoroman17
I am confusing.
Any person can explain me or can share with me information about to calculate the motors, drives, ratio of reduction, choose better system of transmission to my application, acceleration, inertia, velocity, etc.
All information is very valuable to me.
Time to create page: 0.069 seconds
