Plasma cutting with servo System in LinuxCNC
23 Oct 2012 16:05 #25684 by diegoroman17
Replied by diegoroman17 on topic Re:Plasma cutting with servo System in LinuxCNC
Is it capable of generating G code compatible with your thcud.comp, plasma.hal, touchoff.ngc, etc?
23 Oct 2012 16:14 #25685 by BigJohnT
I don't use the thcud.comp I use the thc.comp.
You can modify the post processor in Sheetcam to do whatever you like. I think there is a copy of my post processor on my web site.
gnipsel.com/shop/plasma/plasma.xhtml
23 Oct 2012 16:56 #25691 by diegoroman17
But in your web side is thcud.comp in seccion thc up/down component.
23 Oct 2012 17:11 #25693 by BigJohnT
Yes, I modified the thc.comp that comes with LinuxCNC for someone to have up/down input instead of the frequency input from the THCAD card.
23 Oct 2012 18:30 #25696 by diegoroman17
Ok. Then I have to use thc.comp of linuxcnc without modifications.
27 Oct 2012 04:36 #25859 by diegoroman17
I have calculated the torque to my plasma cutting machine and this is 900 oz-in. Can you suggest me any combo servo driver that it is compatible with 7i77?
27 Oct 2012 06:45 #25861 by PCW
for any suggestions there are some basic questions that need to be answered:
900 oz-in at what RPM? (to calculate motor/drive Watts)
Do you need AC servos or are DC servos adequate?
Do they have to be new?
What is your budget?
27 Oct 2012 07:01 #25862 by diegoroman17
3000 RPM
I don't know in that influence AC or DC if 900 oz - in and 3000RPM are reached with DC servo then I need DC servo.
I need new
The budget is not principal in this case, but the important thing for me is to have a proper functioning.
The following user(s) said Thank You: PCW
27 Oct 2012 07:11 #25863 by PCW
OK thats a really big servo (2KW) if 900 oz-in/3000RPM is a continuous rating
Is the 900 oz.inch based on maximum acceleration ?
Servo drives will usually provide 2-5 times their continuous torque rating
for a fair percentage of the time, so if 900 Oz in is a peak requirement,
a smaller (1 KW or even smaller) servo would probably do
Is this a gantry machine? what is the mass and desired acceleration of the
most massive axis?
27 Oct 2012 07:30 #25864 by diegoroman17
Yes it is a peak torque. I need a 1KW servo.
I need move 85 Kg at 3G (aprox 30m/s^2) is it posible? What acceleration is common in Cutting plasma?
Yes, it is a gantry machine.
Time to create page: 0.072 seconds
