Plasma cutting with servo System in LinuxCNC
18 Oct 2012 20:45 #25425 by diegoroman17
Plasma cutting with servo System in LinuxCNC was created by diegoroman17
Hi everybody,
I need your help already. I want to design a plasma cutting machine with linuxCNC in the core of the system. The mechanics parts are very big and I think that it need design a servo system with AC servo Motors. now I don“t know how begin this task. What drivers I have choose?What AC servo motor I have choose? How I can control the plasma? What cards I need for control?
18 Oct 2012 22:47 #25426 by BigJohnT
A Mesa 5i25 7i77 and THCAD would take care of electronics. You need to calculate the mass of your moving parts to determine what servo / drive combo would work for you. I built a floating torch holder with a micro switch to "touch off" on the material top.
18 Oct 2012 23:16 #25428 by diegoroman17
Replied by diegoroman17 on topic Re:Plasma cutting with servo System in LinuxCNC
Can you explain me more about your system touch off and micro switch? Can you show me any picture? I have begun to calculate the mass.
19 Oct 2012 00:19 #25430 by BigJohnT
The torch is bolted to the slide and when the tip touches the material the slide moves up a bit and touches the micro switch. The move is a probe move. If you back up one from the first link you can see the rest of the plasma info.
A couple of photos here
gnipsel.com/shop/plasma/plasma-gallery.xhtml
and more here
s47.beta.photobucket.com/user/johnplctec...rary/Plasma%20Cutter
19 Oct 2012 14:34 #25439 by diegoroman17
(#1 pierce height, #2 pierce delay, #3 cut height)
Ok, thank you. I have saw your pictures and your O sub for touch off. Only I dont understand how it work with respect to #1 #2 #3 variables? That values are this? can you explain me please?
19 Oct 2012 15:37 #25440 by BigJohnT
When you call the touchoff sub you pass the three variables to it.
linuxcnc.org/docs/html/gcode/o-code.html#_calling_files
19 Oct 2012 15:46 #25441 by diegoroman17
Ok, I understand but I do not know what role each of these variables.
19 Oct 2012 16:05 #25442 by BigJohnT
pierce height is how high the tip should be when the arc is fired
pierce delay is how long to wait before starting the cut
cut height is cut height
All those will be in the cut charts for your torch.
19 Oct 2012 16:20 #25444 by diegoroman17
Thanks John now I understand :)
19 Oct 2012 21:24 #25462 by diegoroman17
Other question. How connect the THCAD to my plasma? What version 10 or 300 I need to my system?I am a beginner with respect to plasma cutting system.
