Limit to number of tools in tool table
- LearningLinuxCNC
- Thank you received: 39
09 Sep 2015 19:43 #62317
by LearningLinuxCNC
Limit to number of tools in tool table was created by LearningLinuxCNC
Is there a limit to the number of tools in the tool table? I was under the impression only 99 tools were allowed. However I can't find reference to that now. I recently saw in another post that someone had a tool number T9999.
Just wondering if there is a limit?
- BigJohnT
- Thank you received: 994
09 Sep 2015 21:19 #62321
by BigJohnT
Replied by BigJohnT on topic Limit to number of tools in tool table
Assuming your talking about a recent version of LinuxCNC...
linuxcnc.org/docs/html/gcode/tool-compen....html#sec:tool-table
JT
JT
- Thank you received: 4648
09 Sep 2015 23:19 #62332
You can have a total of 56 tools, but the tool numbers can be as big as you want.
Replied by andypugh on topic Limit to number of tools in tool table
- LearningLinuxCNC
09 Sep 2015 23:31 #62334
by LearningLinuxCNC
Replied by LearningLinuxCNC on topic Limit to number of tools in tool table
This brings up another question. Why are we limited to 56 tools? I would like to have a single tool table that is consistent from Fusion 360 to LinuxCNC. However with a limit of 56 tools I will have to change my LinuxCNC tool table if my required tools change. This is a pain.
Does anyone know the reason behind the limit of 56 tools in the table? Is this something that could be changed?
Note I have not ran into the limit yet but I am sure I will shortly. Different drill sizes are the real culprit.
10 Sep 2015 00:37 #62338
Yes, the tool data is passed around between the different modules in a fixed size structure that only has room for 56 tools.
It's crazy, and I actually did a lot of work to fix it and put the tool data in an SQL database. But it was widely ignored.
it's the andypugh/tooltable branch here: git.linuxcnc.org/gitweb?p=linuxcnc.git;a=heads
The following user(s) said Thank You: LearningLinuxCNC
- cncbasher
- Thank you received: 202
10 Sep 2015 02:40 #62342
by cncbasher
Replied by cncbasher on topic Limit to number of tools in tool table
Andy i publicly vote for this to be put into the mainstream code base . it really should be there.
their are many users with big tool tables myself included
- LearningLinuxCNC
10 Sep 2015 02:43 #62343
by LearningLinuxCNC
I vote for this also.
- jtc
- Thank you received: 12
10 Sep 2015 03:05 #62345
by jtc
I have reached the 56 tools limit on 2 machines, and that is simply annoying
And when this limit was reached, find that the number of tools in the tool table is the problem it's kind of difficult, linuxcnc don“t even starts so the tool table has to be edited manually.
My vote is for a SQL database solution, that permits some flexibility on the future. Some triggers that update automatically the tools offsets if changed on the database should be great.
Replied by jtc on topic Limit to number of tools in tool table
- BigJohnT
10 Sep 2015 03:23 #62346
by BigJohnT
Commit it to master so it can get some testing. People using master expect it to break from time to time.
JT
JT
- Thank you received: 2173
10 Sep 2015 04:08 #62347
Replied by cmorley on topic Limit to number of tools in tool table
Andy:
When i get no response such as you did - I take it as a go-ahead.
I announce that i'm going to add it to master unless i hear a good reason not too.
and after that I will commit it to master. once it's in master if there is a real reason not to have it there,
devs will be more forward.
It has happened a few times for me and wasn't negative.
And I vote for your work on tool table too.
and for JA branch
In fact I think we should peel off a 2.8 branch off master now then add JA right away.
It's the only way it will get added any time reasonable.
IMHO
Chris M
and for JA branch
IMHO
Chris M
The following user(s) said Thank You: BigJohnT
Time to create page: 0.177 seconds
