Limit to number of tools in tool table
10 Sep 2015 04:14 #62348 by andypugh
Replied by andypugh on topic Limit to number of tools in tool table
I vote for this also.
It's all very well voting for it, but I am not sure that it works properly, as it is just a proof of concept.
The version there uses a database structure that is nowhere near as flexible as it could be. I really think that the database should look like this:
wiki.linuxcnc.org/cgi-bin/wiki.pl?ToolDatabase
But _look_ like the current one from the point of view of the tool editor.
(which needs to be changed to work with a database).
10 Sep 2015 04:41 #62349 by jtc
Replied by jtc on topic Limit to number of tools in tool table
for what I see, that concept it's not intended to use with lathes... please don't forget about lathes.
10 Sep 2015 04:49 #62350 by andypugh
Not so, it is entirely applicable to lathes, even dual-spindle lathes with two carousels, if need be.
I am much more a lathe user than a mill user, I will not be forgetting lathes.
The following user(s) said Thank You: jtc
10 Sep 2015 04:56 #62351 by BigJohnT
Replied by BigJohnT on topic Limit to number of tools in tool table
I've done a lot of work with Python using databases so if you need some help in that area I'm in.
JT
  • LearningLinuxCNC
  • LearningLinuxCNC's Avatar Topic Author
  • Elite Member
  • Elite Member
10 Sep 2015 05:02 #62352 by LearningLinuxCNC
Replied by LearningLinuxCNC on topic Limit to number of tools in tool table
I am glad to help with testing of this. If I can help with programming I can do that also. Relatively new to python but I have coded in VB, VB.net, C, C++, Fortran ......... Not an expert but I might be able to help. I have also done quite a bit of work on database stuff.
I have never used GIT before though. That is something that I am trying to figure out.
I also need to figure out how to do a run in place configuration for testing purposes.
10 Sep 2015 05:08 #62353 by jtc
see if this tutorial it's suitable for you.
www.wiki.eusurplus.com/index.php?title=LinuxCNC_Run_In_Place
João
10 Sep 2015 05:11 #62354 by BigJohnT
Maybe you can help me with C++ and I can help you with Python :)
JT
10 Sep 2015 05:19 #62358 by cmorley
Replied by cmorley on topic Limit to number of tools in tool table
The tooleditor I think you are referring to is written in TCL ...uggg
But the GladeVCP one is written in python (and can run stand alone too) I can modify that one for you.
(when I'm back from working away that is)
  • LearningLinuxCNC
  • Elite Member
  • Elite Member
10 Sep 2015 05:41 #62360 by LearningLinuxCNC
JT
My worst programming nightmares were while I was automating Pro Engineer with C++ and the ProE API.
Pointer here, Pointer there, Horrible debugging AHHHHHHHHH! So many years ago, I had almost forgotten the horrors.
From my initial impressions and playing I like Python better!
04 Jul 2018 19:43 - 06 Jul 2018 23:19 #113440 by ciccio85
Replied by ciccio85 on topic Limit to number of tools in tool table
Hello,
any news about this feature?
I found this workaround: github.com/LinuxCNC/linuxcnc/issues/411
and seems to work!
Last edit: 06 Jul 2018 23:19 by ciccio85. Reason: New information
