Jrjones wrote: Yes, the drives need a 15.5 kHz differential PWM signal, so 2 PWM signals per drive.
Just to clarify where the confusion is, you have two PWM outputs per PWM module. So only 3 PWMs. Standard PWM has 2 pins per module two, PWM and direction. If you look at
git.linuxcnc.org/gitweb?p=hostmot2-firmw...fe5a983ab494e0a49b49
you will see the subtle difference.
Going back a posting or two, you don't really need the config wizard to know about your daughter card in detail as firmware sets what pins exist in the sense of whether you see stepgens or pwms and encoders etc, but the HAL pins remain the same regardless of the physical pinouts on the cards. So, hm2_7i92.0.pwm.00.value will drive pins 2 and 15 in the DB25 on the 7i92 with the .bit file you are looking at, but might drive completely different physical pins with different bit file.
git.linuxcnc.org/gitweb?p=hostmot2-firmw...a263cff8d9c8;hb=HEAD
Defines the bitfiles that are created as part of the hostmot2-firmware package, which doesn't seem to include any 7i92 card definitions.
However, the 7i92.vhd etc do appear to exist in the hotmot2.zip file from Mesa. (which you will find inside 7i92,zip inside the Hostmot2/source folder)
I did have a Virtual Machine set up to create bitfiles, but I think I lost it to a HD failure, otherwise I would have offered to build you the bitfile.
The simplest solution is to ask PCW to build the bitfile for you, but it also seems that the LinuxCNC Hostmot2 repository needs updating to add the 7i92 and start autobuilding firmwares.
