Ok, I've got the 7i92_7i85sx2D.bit firmware flashed to the 7i92.
The readhmid command gives me this output, which looks right from the 7i85S documentation.
Configuration Name: HOSTMOT2
BoardName : MESA7I92
FPGA Size: 9 KGates
FPGA Pins: 144
Number of IO Ports: 2
Width of one I/O port: 17
Clock Low frequency: 100.0000 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: DPLL
There are 1 of DPLL in configuration
Version: 0
Registers: 7
BaseAddress: 7000
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
There are 2 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: MuxedQCount
There are 8 of MuxedQCount in configuration
Version: 3
Registers: 5
BaseAddress: 3500
Module: MuxedQCountSel
There are 1 of MuxedQCountSel in configuration
Version: 0
Registers: 0
BaseAddress: 0000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5A00
Instance Stride: 64 bytes
Module: StepGen
There are 8 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P2
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
1 0 IOPort SSerial 0 RXData1 (In)
14 1 IOPort SSerial 0 TXData1 (Out)
2 2 IOPort StepGen 3 Step/Table1 (Out)
15 3 IOPort StepGen 3 Dir/Table2 (Out)
3 4 IOPort StepGen 2 Step/Table1 (Out)
16 5 IOPort StepGen 2 Dir/Table2 (Out)
4 6 IOPort StepGen 1 Step/Table1 (Out)
17 7 IOPort StepGen 1 Dir/Table2 (Out)
5 8 IOPort StepGen 0 Step/Table1 (Out)
6 9 IOPort StepGen 0 Dir/Table2 (Out)
7 10 IOPort MuxedQCountSel 0 MuxSel0 (Out)
8 11 IOPort MuxedQCount 0 MuxQ-A (In)
9 12 IOPort MuxedQCount 0 MuxQ-B (In)
10 13 IOPort MuxedQCount 0 MuxQ-IDX (In)
11 14 IOPort MuxedQCount 1 MuxQ-A (In)
12 15 IOPort MuxedQCount 1 MuxQ-B (In)
13 16 IOPort MuxedQCount 1 MuxQ-IDX (In)
IO Connections for P1
1 17 IOPort SSerial 0 RXData2 (In)
14 18 IOPort SSerial 0 TXData2 (Out)
2 19 IOPort StepGen 7 Step/Table1 (Out)
15 20 IOPort StepGen 7 Dir/Table2 (Out)
3 21 IOPort StepGen 6 Step/Table1 (Out)
16 22 IOPort StepGen 6 Dir/Table2 (Out)
4 23 IOPort StepGen 5 Step/Table1 (Out)
17 24 IOPort StepGen 5 Dir/Table2 (Out)
5 25 IOPort StepGen 4 Step/Table1 (Out)
6 26 IOPort StepGen 4 Dir/Table2 (Out)
7 27 IOPort MuxedQCountSel 4 MuxSel0 (Out)
8 28 IOPort MuxedQCount 2 MuxQ-A (In)
9 29 IOPort MuxedQCount 2 MuxQ-B (In)
10 30 IOPort MuxedQCount 2 MuxQ-IDX (In)
11 31 IOPort MuxedQCount 3 MuxQ-A (In)
12 32 IOPort MuxedQCount 3 MuxQ-B (In)
13 33 IOPort MuxedQCount 3 MuxQ-IDX (In)
I'm a little confused how to configure a 5i25, since the 7i85S doesn't appear under the firmware list, and none of the options let me select 6 PWM generators and 3 encoders.
As an aside, is it a problem that the machine doesn't have any home/limit switches? With the Prototrak software, you manually moved the mill to a position and set that as home.
