Where to start with Mesa 7i92 + 7i85S
10 years 9 months ago #68074 by Jrjones
Thanks for the bit file cncbasher.
It appears to have loaded correctly, I did load it into the fallback area as PCW suggested in case it didn't work.
Configuration Name: HOSTMOT2 General configuration information: BoardName : MESA7I92 FPGA Size: 9 KGates FPGA Pins: 144 Number of IO Ports: 2 Width of one I/O port: 17 Clock Low frequency: 100.0000 MHz Clock High frequency: 200.0000 MHz IDROM Type: 3 Instance Stride 0: 4 Instance Stride 1: 64 Register Stride 0: 256 Register Stride 1: 256 Modules in configuration: Module: WatchDog There are 1 of WatchDog in configuration Version: 0 Registers: 3 BaseAddress: 0C00 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: IOPort There are 2 of IOPort in configuration Version: 0 Registers: 5 BaseAddress: 1000 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: MuxedQCount There are 8 of MuxedQCount in configuration Version: 3 Registers: 5 BaseAddress: 3600 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: MuxedQCountSel There are 1 of MuxedQCountSel in configuration Version: 0 Registers: 0 BaseAddress: 0000 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: SSerial There are 1 of SSerial in configuration Version: 0 Registers: 6 BaseAddress: 5B00 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 64 bytes Module: PWM There are 8 of PWM in configuration Version: 0 Registers: 5 BaseAddress: 4100 ClockFrequency: 200.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: LED There are 1 of LED in configuration Version: 0 Registers: 1 BaseAddress: 0200 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Configuration pin-out: IO Connections for P2 Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir 1 0 IOPort SSerial 0 RXData1 (In) 14 1 IOPort SSerial 0 TXData1 (Out) 2 2 IOPort PWM 3 PWM (Out) 15 3 IOPort PWM 3 Dir (Out) 3 4 IOPort PWM 2 PWM (Out) 16 5 IOPort PWM 2 Dir (Out) 4 6 IOPort PWM 1 PWM (Out) 17 7 IOPort PWM 1 Dir (Out) 5 8 IOPort PWM 0 PWM (Out) 6 9 IOPort PWM 0 Dir (Out) 7 10 IOPort MuxedQCountSel 0 MuxSel0 (Out) 8 11 IOPort MuxedQCount 0 MuxQ-A (In) 9 12 IOPort MuxedQCount 0 MuxQ-B (In) 10 13 IOPort MuxedQCount 0 MuxQ-IDX (In) 11 14 IOPort MuxedQCount 1 MuxQ-A (In) 12 15 IOPort MuxedQCount 1 MuxQ-B (In) 13 16 IOPort MuxedQCount 1 MuxQ-IDX (In) IO Connections for P1 Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir 1 17 IOPort SSerial 0 RXData2 (In) 14 18 IOPort SSerial 0 TXData2 (Out) 2 19 IOPort PWM 7 PWM (Out) 15 20 IOPort PWM 7 Dir (Out) 3 21 IOPort PWM 6 PWM (Out) 16 22 IOPort PWM 6 Dir (Out) 4 23 IOPort PWM 5 PWM (Out) 17 24 IOPort PWM 5 Dir (Out) 5 25 IOPort PWM 4 PWM (Out) 6 26 IOPort PWM 4 Dir (Out) 7 27 IOPort MuxedQCountSel 4 MuxSel0 (Out) 8 28 IOPort MuxedQCount 2 MuxQ-A (In) 9 29 IOPort MuxedQCount 2 MuxQ-B (In) 10 30 IOPort MuxedQCount 2 MuxQ-IDX (In) 11 31 IOPort MuxedQCount 3 MuxQ-A (In) 12 32 IOPort MuxedQCount 3 MuxQ-B (In) 13 33 IOPort MuxedQCount 3 MuxQ-IDX (In)
So I should be to configure the Dir pin as a second (inverted) complement to the primary PWM pin?
10 years 9 months ago #68076 by andypugh
Jrjones wrote: So I should be to configure the Dir pin as a second (inverted) complement to the primary PWM pin?
Is that what you need?
The 7i85S outputs are in differential pairs, TX0 and /TX0 for example.
The potential output configs for the PWM are here:
linuxcnc.org/docs/2.7/html/man/man9/hostmot2.9.html#pwmgen
But it is possible that the bitfile you have has a special pwmgen.
10 years 9 months ago #68110 by PCW
The 7i85spx2 config has standard pwmgens. The direction outputs are not useful for the locked antiphase
PWM mode that you need so will not be used with this configuration. As far as has been determined, the
Prototrac drives use a single PWM signal per drive, but the signal is transmitted differentially so requires
a differential pair (2 wires that carry the same PWM signal but with opposite polarities)
10 years 6 months ago #73027 by techrat
I am attempting to do pretty much the same exact thing as Jrjones except I am using the 5i25/7i85s combination. I was on the fence about starting a new thread or jumping in on this one. In the end, I decided to jump in here as I am at about the same progress point and I think that answers to our respective questions will likely help one another.
Basics:
Same machine/servos/amps that JrJones is using.
5i25/7i85s boards
5i25 installed in PC running LINUXCNC - 2.7.0
7i85 not currently connected to 5i25 (just not connecting until I am sure I am ready)
5i25 flashed with 5i25_7i85spx2.bit downloaded from Mesa Website
OUTPUT FROM mesaflash -verify
sudo mesaflash --device 5I25 --verify ../configs/hostmot2/5i25_7i85spx2.bit Checking file... OK File type: BIT file Boot sector OK Verifying EEPROM sectors starting from 0x100000... |VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV Board configuration verified successfully.
OUTPUT FROM halcmd: show pin
halcmd: loadrt hm2_pci halcmd: show pin Component Pins: Owner Type Dir Value Name 5 s32 OUT 0 hm2_5i25.0.encoder.00.count 5 s32 OUT 0 hm2_5i25.0.encoder.00.count-latched 5 bit I/O FALSE hm2_5i25.0.encoder.00.index-enable 5 bit OUT TRUE hm2_5i25.0.encoder.00.input-a 5 bit OUT TRUE hm2_5i25.0.encoder.00.input-b 5 bit OUT FALSE hm2_5i25.0.encoder.00.input-index 5 bit IN FALSE hm2_5i25.0.encoder.00.latch-enable 5 bit IN FALSE hm2_5i25.0.encoder.00.latch-polarity 5 float OUT 0 hm2_5i25.0.encoder.00.position 5 float OUT 0 hm2_5i25.0.encoder.00.position-latched 5 bit OUT FALSE hm2_5i25.0.encoder.00.quad-error 5 bit IN FALSE hm2_5i25.0.encoder.00.quad-error-enable 5 s32 OUT 0 hm2_5i25.0.encoder.00.rawcounts 5 s32 OUT 0 hm2_5i25.0.encoder.00.rawlatch 5 bit IN FALSE hm2_5i25.0.encoder.00.reset 5 float OUT 0 hm2_5i25.0.encoder.00.velocity 5 s32 OUT 0 hm2_5i25.0.encoder.01.count 5 s32 OUT 0 hm2_5i25.0.encoder.01.count-latched 5 bit I/O FALSE hm2_5i25.0.encoder.01.index-enable 5 bit OUT TRUE hm2_5i25.0.encoder.01.input-a 5 bit OUT TRUE hm2_5i25.0.encoder.01.input-b 5 bit OUT FALSE hm2_5i25.0.encoder.01.input-index 5 bit IN FALSE hm2_5i25.0.encoder.01.latch-enable 5 bit IN FALSE hm2_5i25.0.encoder.01.latch-polarity 5 float OUT 0 hm2_5i25.0.encoder.01.position 5 float OUT 0 hm2_5i25.0.encoder.01.position-latched 5 bit OUT FALSE hm2_5i25.0.encoder.01.quad-error 5 bit IN FALSE hm2_5i25.0.encoder.01.quad-error-enable 5 s32 OUT 0 hm2_5i25.0.encoder.01.rawcounts 5 s32 OUT 0 hm2_5i25.0.encoder.01.rawlatch 5 bit IN FALSE hm2_5i25.0.encoder.01.reset 5 float OUT 0 hm2_5i25.0.encoder.01.velocity 5 s32 OUT 0 hm2_5i25.0.encoder.02.count 5 s32 OUT 0 hm2_5i25.0.encoder.02.count-latched 5 bit I/O FALSE hm2_5i25.0.encoder.02.index-enable 5 bit OUT TRUE hm2_5i25.0.encoder.02.input-a 5 bit OUT TRUE hm2_5i25.0.encoder.02.input-b 5 bit OUT FALSE hm2_5i25.0.encoder.02.input-index 5 bit IN FALSE hm2_5i25.0.encoder.02.latch-enable 5 bit IN FALSE hm2_5i25.0.encoder.02.latch-polarity 5 float OUT 0 hm2_5i25.0.encoder.02.position 5 float OUT 0 hm2_5i25.0.encoder.02.position-latched 5 bit OUT FALSE hm2_5i25.0.encoder.02.quad-error 5 bit IN FALSE hm2_5i25.0.encoder.02.quad-error-enable 5 s32 OUT 0 hm2_5i25.0.encoder.02.rawcounts 5 s32 OUT 0 hm2_5i25.0.encoder.02.rawlatch 5 bit IN FALSE hm2_5i25.0.encoder.02.reset 5 float OUT 0 hm2_5i25.0.encoder.02.velocity 5 s32 OUT 0 hm2_5i25.0.encoder.03.count 5 s32 OUT 0 hm2_5i25.0.encoder.03.count-latched 5 bit I/O FALSE hm2_5i25.0.encoder.03.index-enable 5 bit OUT TRUE hm2_5i25.0.encoder.03.input-a 5 bit OUT TRUE hm2_5i25.0.encoder.03.input-b 5 bit OUT FALSE hm2_5i25.0.encoder.03.input-index 5 bit IN FALSE hm2_5i25.0.encoder.03.latch-enable 5 bit IN FALSE hm2_5i25.0.encoder.03.latch-polarity 5 float OUT 0 hm2_5i25.0.encoder.03.position 5 float OUT 0 hm2_5i25.0.encoder.03.position-latched 5 bit OUT FALSE hm2_5i25.0.encoder.03.quad-error 5 bit IN FALSE hm2_5i25.0.encoder.03.quad-error-enable 5 s32 OUT 0 hm2_5i25.0.encoder.03.rawcounts 5 s32 OUT 0 hm2_5i25.0.encoder.03.rawlatch 5 bit IN FALSE hm2_5i25.0.encoder.03.reset 5 float OUT 0 hm2_5i25.0.encoder.03.velocity 5 s32 OUT 0 hm2_5i25.0.encoder.04.count 5 s32 OUT 0 hm2_5i25.0.encoder.04.count-latched 5 bit I/O FALSE hm2_5i25.0.encoder.04.index-enable 5 bit OUT TRUE hm2_5i25.0.encoder.04.input-a 5 bit OUT TRUE hm2_5i25.0.encoder.04.input-b 5 bit OUT FALSE hm2_5i25.0.encoder.04.input-index 5 bit IN FALSE hm2_5i25.0.encoder.04.latch-enable 5 bit IN FALSE hm2_5i25.0.encoder.04.latch-polarity 5 float OUT 0 hm2_5i25.0.encoder.04.position 5 float OUT 0 hm2_5i25.0.encoder.04.position-latched 5 bit OUT FALSE hm2_5i25.0.encoder.04.quad-error 5 bit IN FALSE hm2_5i25.0.encoder.04.quad-error-enable 5 s32 OUT 0 hm2_5i25.0.encoder.04.rawcounts 5 s32 OUT 0 hm2_5i25.0.encoder.04.rawlatch 5 bit IN FALSE hm2_5i25.0.encoder.04.reset 5 float OUT 0 hm2_5i25.0.encoder.04.velocity 5 s32 OUT 0 hm2_5i25.0.encoder.05.count 5 s32 OUT 0 hm2_5i25.0.encoder.05.count-latched 5 bit I/O FALSE hm2_5i25.0.encoder.05.index-enable 5 bit OUT TRUE hm2_5i25.0.encoder.05.input-a 5 bit OUT TRUE hm2_5i25.0.encoder.05.input-b 5 bit OUT FALSE hm2_5i25.0.encoder.05.input-index 5 bit IN FALSE hm2_5i25.0.encoder.05.latch-enable 5 bit IN FALSE hm2_5i25.0.encoder.05.latch-polarity 5 float OUT 0 hm2_5i25.0.encoder.05.position 5 float OUT 0 hm2_5i25.0.encoder.05.position-latched 5 bit OUT FALSE hm2_5i25.0.encoder.05.quad-error 5 bit IN FALSE hm2_5i25.0.encoder.05.quad-error-enable 5 s32 OUT 0 hm2_5i25.0.encoder.05.rawcounts 5 s32 OUT 0 hm2_5i25.0.encoder.05.rawlatch 5 bit IN FALSE hm2_5i25.0.encoder.05.reset 5 float OUT 0 hm2_5i25.0.encoder.05.velocity 5 s32 OUT 0 hm2_5i25.0.encoder.06.count 5 s32 OUT 0 hm2_5i25.0.encoder.06.count-latched 5 bit I/O FALSE hm2_5i25.0.encoder.06.index-enable 5 bit OUT TRUE hm2_5i25.0.encoder.06.input-a 5 bit OUT TRUE hm2_5i25.0.encoder.06.input-b 5 bit OUT FALSE hm2_5i25.0.encoder.06.input-index 5 bit IN FALSE hm2_5i25.0.encoder.06.latch-enable 5 bit IN FALSE hm2_5i25.0.encoder.06.latch-polarity 5 float OUT 0 hm2_5i25.0.encoder.06.position 5 float OUT 0 hm2_5i25.0.encoder.06.position-latched 5 bit OUT FALSE hm2_5i25.0.encoder.06.quad-error 5 bit IN FALSE hm2_5i25.0.encoder.06.quad-error-enable 5 s32 OUT 0 hm2_5i25.0.encoder.06.rawcounts 5 s32 OUT 0 hm2_5i25.0.encoder.06.rawlatch 5 bit IN FALSE hm2_5i25.0.encoder.06.reset 5 float OUT 0 hm2_5i25.0.encoder.06.velocity 5 s32 OUT 0 hm2_5i25.0.encoder.07.count 5 s32 OUT 0 hm2_5i25.0.encoder.07.count-latched 5 bit I/O FALSE hm2_5i25.0.encoder.07.index-enable 5 bit OUT TRUE hm2_5i25.0.encoder.07.input-a 5 bit OUT TRUE hm2_5i25.0.encoder.07.input-b 5 bit OUT FALSE hm2_5i25.0.encoder.07.input-index 5 bit IN FALSE hm2_5i25.0.encoder.07.latch-enable 5 bit IN FALSE hm2_5i25.0.encoder.07.latch-polarity 5 float OUT 0 hm2_5i25.0.encoder.07.position 5 float OUT 0 hm2_5i25.0.encoder.07.position-latched 5 bit OUT FALSE hm2_5i25.0.encoder.07.quad-error 5 bit IN FALSE hm2_5i25.0.encoder.07.quad-error-enable 5 s32 OUT 0 hm2_5i25.0.encoder.07.rawcounts 5 s32 OUT 0 hm2_5i25.0.encoder.07.rawlatch 5 bit IN FALSE hm2_5i25.0.encoder.07.reset 5 float OUT 0 hm2_5i25.0.encoder.07.velocity 5 u32 IN 0x007F2815 hm2_5i25.0.encoder.muxed-sample-frequency 5 bit OUT TRUE hm2_5i25.0.gpio.000.in 5 bit OUT FALSE hm2_5i25.0.gpio.000.in_not 5 bit IN FALSE hm2_5i25.0.gpio.000.out 5 bit OUT TRUE hm2_5i25.0.gpio.001.in 5 bit OUT FALSE hm2_5i25.0.gpio.001.in_not 5 bit IN FALSE hm2_5i25.0.gpio.001.out 5 bit OUT FALSE hm2_5i25.0.gpio.002.in 5 bit OUT TRUE hm2_5i25.0.gpio.002.in_not 5 bit OUT FALSE hm2_5i25.0.gpio.003.in 5 bit OUT TRUE hm2_5i25.0.gpio.003.in_not 5 bit OUT FALSE hm2_5i25.0.gpio.004.in 5 bit OUT TRUE hm2_5i25.0.gpio.004.in_not 5 bit OUT FALSE hm2_5i25.0.gpio.005.in 5 bit OUT TRUE hm2_5i25.0.gpio.005.in_not 5 bit OUT FALSE hm2_5i25.0.gpio.006.in 5 bit OUT TRUE hm2_5i25.0.gpio.006.in_not 5 bit OUT FALSE hm2_5i25.0.gpio.007.in 5 bit OUT TRUE hm2_5i25.0.gpio.007.in_not 5 bit OUT FALSE hm2_5i25.0.gpio.008.in 5 bit OUT TRUE hm2_5i25.0.gpio.008.in_not 5 bit OUT FALSE hm2_5i25.0.gpio.009.in 5 bit OUT TRUE hm2_5i25.0.gpio.009.in_not 5 bit OUT FALSE hm2_5i25.0.gpio.010.in 5 bit OUT TRUE hm2_5i25.0.gpio.010.in_not 5 bit OUT TRUE hm2_5i25.0.gpio.011.in 5 bit OUT FALSE hm2_5i25.0.gpio.011.in_not 5 bit OUT TRUE hm2_5i25.0.gpio.012.in 5 bit OUT FALSE hm2_5i25.0.gpio.012.in_not 5 bit OUT TRUE hm2_5i25.0.gpio.013.in 5 bit OUT FALSE hm2_5i25.0.gpio.013.in_not 5 bit OUT TRUE hm2_5i25.0.gpio.014.in 5 bit OUT FALSE hm2_5i25.0.gpio.014.in_not 5 bit OUT TRUE hm2_5i25.0.gpio.015.in 5 bit OUT FALSE hm2_5i25.0.gpio.015.in_not 5 bit OUT TRUE hm2_5i25.0.gpio.016.in 5 bit OUT FALSE hm2_5i25.0.gpio.016.in_not 5 bit OUT TRUE hm2_5i25.0.gpio.017.in 5 bit OUT FALSE hm2_5i25.0.gpio.017.in_not 5 bit IN FALSE hm2_5i25.0.gpio.017.out 5 bit OUT TRUE hm2_5i25.0.gpio.018.in 5 bit OUT FALSE hm2_5i25.0.gpio.018.in_not 5 bit IN FALSE hm2_5i25.0.gpio.018.out 5 bit OUT FALSE hm2_5i25.0.gpio.019.in 5 bit OUT TRUE hm2_5i25.0.gpio.019.in_not 5 bit OUT FALSE hm2_5i25.0.gpio.020.in 5 bit OUT TRUE hm2_5i25.0.gpio.020.in_not 5 bit OUT FALSE hm2_5i25.0.gpio.021.in 5 bit OUT TRUE hm2_5i25.0.gpio.021.in_not 5 bit OUT FALSE hm2_5i25.0.gpio.022.in 5 bit OUT TRUE hm2_5i25.0.gpio.022.in_not 5 bit OUT FALSE hm2_5i25.0.gpio.023.in 5 bit OUT TRUE hm2_5i25.0.gpio.023.in_not 5 bit OUT FALSE hm2_5i25.0.gpio.024.in 5 bit OUT TRUE hm2_5i25.0.gpio.024.in_not 5 bit OUT FALSE hm2_5i25.0.gpio.025.in 5 bit OUT TRUE hm2_5i25.0.gpio.025.in_not 5 bit OUT FALSE hm2_5i25.0.gpio.026.in 5 bit OUT TRUE hm2_5i25.0.gpio.026.in_not 5 bit OUT FALSE hm2_5i25.0.gpio.027.in 5 bit OUT TRUE hm2_5i25.0.gpio.027.in_not 5 bit OUT TRUE hm2_5i25.0.gpio.028.in 5 bit OUT FALSE hm2_5i25.0.gpio.028.in_not 5 bit OUT TRUE hm2_5i25.0.gpio.029.in 5 bit OUT FALSE hm2_5i25.0.gpio.029.in_not 5 bit OUT TRUE hm2_5i25.0.gpio.030.in 5 bit OUT FALSE hm2_5i25.0.gpio.030.in_not 5 bit OUT TRUE hm2_5i25.0.gpio.031.in 5 bit OUT FALSE hm2_5i25.0.gpio.031.in_not 5 bit OUT TRUE hm2_5i25.0.gpio.032.in 5 bit OUT FALSE hm2_5i25.0.gpio.032.in_not 5 bit OUT TRUE hm2_5i25.0.gpio.033.in 5 bit OUT FALSE hm2_5i25.0.gpio.033.in_not 5 bit IN FALSE hm2_5i25.0.led.CR01 5 bit IN FALSE hm2_5i25.0.led.CR02 5 bit IN FALSE hm2_5i25.0.pwmgen.00.enable 5 float IN 0 hm2_5i25.0.pwmgen.00.value 5 bit IN FALSE hm2_5i25.0.pwmgen.01.enable 5 float IN 0 hm2_5i25.0.pwmgen.01.value 5 bit IN FALSE hm2_5i25.0.pwmgen.02.enable 5 float IN 0 hm2_5i25.0.pwmgen.02.value 5 bit IN FALSE hm2_5i25.0.pwmgen.03.enable 5 float IN 0 hm2_5i25.0.pwmgen.03.value 5 bit IN FALSE hm2_5i25.0.pwmgen.04.enable 5 float IN 0 hm2_5i25.0.pwmgen.04.value 5 bit IN FALSE hm2_5i25.0.pwmgen.05.enable 5 float IN 0 hm2_5i25.0.pwmgen.05.value 5 bit IN FALSE hm2_5i25.0.pwmgen.06.enable 5 float IN 0 hm2_5i25.0.pwmgen.06.value 5 bit IN FALSE hm2_5i25.0.pwmgen.07.enable 5 float IN 0 hm2_5i25.0.pwmgen.07.value 5 s32 OUT 0 hm2_5i25.0.read.time 5 s32 OUT 0 hm2_5i25.0.read_gpio.time 5 bit I/O FALSE hm2_5i25.0.watchdog.has_bit 5 s32 OUT 0 hm2_5i25.0.write.time 5 s32 OUT 0 hm2_5i25.0.write_gpio.time
With that information out of the way, I am unsure of next steps.
It appears that I can use PNCConf to create a configuration but it appears from previous posts in this thread, this would not be useful for what I need to accomplish. Or is the PNCConf only an issue for jrjones as he is using the 7i92 instead of the 5i25?
Also with regard to the differential signal, does a set of pins already exist using the standard 5i25-7i85spx2 firmware/config. i.e. are TX0 and /TX0 the same pwm with opposite polarity?
I did read through the HAL manual and the HOSTMOT2 documentation and have a reasonable grasp of the information presented in these documents. It appears as though most of the basics of what I need to get started are already available through the firmware/config that I downloaded from MESA. I just want to be sure that I am taking the correct steps.
Please advise on the recommended next actions and/or other documentation that I should be reading.
Thanks - Jeff
10 years 6 months ago #73033 by PCW
I suspect you may be better of starting with a generic servo config (say hm2-servo)
and editing the hal file.
The 7I85S outputs differential signals already (this is a hardware feature and cannot be changed)
whether these differential outputs are step+dir, PWM, serial, etc are a function of the firmware
10 years 6 months ago #73056 by techrat
Looking at the folder created by pncconf here:
~/linuxcnc/configs/my_LinuxCNC_machine
and keeping in mind the advice to start with the generic servo configuration, it appears as though I could keep all of the files except the my_LinuxCNC_machine.hal and replace that file with the hm2-servo.hal from the samples located at
/usr/share/doc/linuxcnc/examples/sample-configs/by_interface/mesa/
Is there any reason to replace the .ini file created by pncconf? Or can I just go in and rename the hal file listed in the .ini to match the hm2-servo from the sample folder? If I am better off using one of the generic .ini files from the sample folder, which should I use? There does not seem to be an .ini specific to the 5i25.
I am sure I could scratch and crawl my way through this but if you all don't mind giving me a sanity check on my assumptions along the way, I will appreciate it.
Thanks! Jeff
Time to create page: 0.146 seconds
