Where to start with Mesa 7i92 + 7i85S
10 years 6 months ago #73057 by BigJohnT
I would not mix the configuration files because the naming conventions in the ini are most likely different. For example one may use MAXACCEL and the other one might use MAX_ACCEL. Any custom name can be used for things read in the hal file.
JT
10 years 6 months ago #73388 by techrat
I am continuing forward using one of the sample .ini files and hand editing as suggested. I also decided to pull one of the motors/encoders/drives to work out the bugs on the bench.
With this in mind, I imagine that I will want to update the .ini file to reflect a single axis. Does this sound correct. Will the hal file need to be updated as well.
Also wondering if, for bench testing, there is anything I should do with regard to limit switches.
Lastly, I understand that tuning the PID settings in a no-load bench scenario is not typically recommended however I imagine that I should be able to get a hello world/proof of concept/ verification of cabling on the bench. Anything I am missing?
10 years 6 months ago #73398 by BigJohnT
You can have as many axes as you want just don't jog and axis you don't have hooked up. You can make a simple pyvcp tab with some buttons to simulate limit switches.
JT
10 years 6 months ago #73669 by techrat
I have had some success; I have connected up my motor drive and encoder and can now see the XAxis DRO move when manually turning the axis motor. I also connected the PWM to the servo amp but was unable to get any activity out of the drive/motor. I feel as though I should be able to manually set the PWM via halcmd and view the resulting signals in the halscope or with an actual scope at the7i85 but how to do this is escaping me.
Any pointers on where to go next to output a PWM signal that I can verify with halscope or actual scope will be appreciated.
Thanks,
Jeff
10 years 6 months ago #73673 by PCW
The PWM outputs need a bit of setup
You need to set the frequency and mode
also the PWM enables must be set true
You will not be able to get a good picture of the PWM via halscope
due to the low sampling rate (but a regular scope should work)
10 years 6 months ago #73704 by techrat
Thank you for the input! I believe that I did the necessary updates to the hal and ini file (see below). I have read through the hostmot2 and hal manual both a few times but am still feeling pretty ignorant.
I have the following questions:
1.) How would I go about commanding the system to output a signal through the 7i85 for the X-Axis using halcmd? (Note when trying to simply jog through the Axis GUI i get a follow error almost immediately. Once the signal is confirmed with a scope, I can connect to the drive and work to further configure.
2.) How do I configure the PWM duty cycle to 50% = No Movement, 50-100% = Positive movement, 50%-0% = Negative Movement?
3.) From the Hal file and .ini below what might I be missing that will prevent me from getting to the point of being able to test a single axis?
I thank that once I get a single proof of concept, I will be able to fill in the blanks.
Sorry if these questions seem as though I am totally lost, I did read through the manuals at least twice. I am just having a mental block on next steps. Feeling a little dense to be honest.
Thanks for any assistance.
HM2-Servo.hal
# ####################################### # # HAL file for HostMot2 with 3 servos # # Derived from Ted Hyde's original hm2-servo config # # Based up work and discussion with Seb & Peter & Jeff # GNU license references - insert here. www.linuxcnc.org # # # ######################################## # Firmware files are in /lib/firmware/hm2/7i43/ # Must symlink the hostmot2 firmware directory of sanbox to # /lib/firmware before running EMC2... # sudo ln -s $HOME/emc2-sandbox/src/hal/drivers/mesa-hostmot2/firmware /lib/firmware/hm2 # # See also: # <http://www.linuxcnc.org/docs/devel/html/man/man9/hostmot2.9.html#config%20modparam> # and http://wiki.linuxcnc.org/cgi-bin/emcinfo.pl?HostMot2 # # ##################################################################### # ################################### # Core EMC/HAL Loads # ################################### # kinematics loadrt trivkins # motion controller, get name and thread periods from ini file loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES # standard components loadrt pid num_chan=3 # hostmot2 driver # if you have any firmware trouble, enable the debug flags here and see what's going on in the syslog #loadrt hostmot2 debug_idrom=1 debug_module_descriptors=1 debug_pin_descriptors=1 debug_modules=1 loadrt hostmot2 # load low-level driver #loadrt [HOSTMOT2](DRIVER) config=[HOSTMOT2](CONFIG) loadrt hm2_pci config=" num_encoders=8 num_pwmgens=8 num_stepgens=0 sserial_port_0=00xxxx" setp hm2_[HOSTMOT2](BOARD).0.pwmgen.pwm_frequency 15000 # ################################################ # THREADS # ################################################ addf hm2_[HOSTMOT2](BOARD).0.read servo-thread addf motion-command-handler servo-thread addf motion-controller servo-thread addf pid.0.do-pid-calcs servo-thread addf pid.1.do-pid-calcs servo-thread addf pid.2.do-pid-calcs servo-thread addf hm2_[HOSTMOT2](BOARD).0.write servo-thread # ###################################################### # Axis-of-motion Specific Configs (not the GUI) # ###################################################### # ################ # X [0] Axis # ################ # axis enable chain newsig emcmot.00.enable bit sets emcmot.00.enable FALSE net emcmot.00.enable => pid.0.enable net emcmot.00.enable => hm2_[HOSTMOT2](BOARD).0.pwmgen.00.enable net emcmot.00.enable <= axis.0.amp-enable-out # encoder feedback setp hm2_[HOSTMOT2](BOARD).0.encoder.00.counter-mode 0 setp hm2_[HOSTMOT2](BOARD).0.encoder.00.filter 1 setp hm2_[HOSTMOT2](BOARD).0.encoder.00.index-invert 0 setp hm2_[HOSTMOT2](BOARD).0.encoder.00.index-mask 0 setp hm2_[HOSTMOT2](BOARD).0.encoder.00.index-mask-invert 0 setp hm2_[HOSTMOT2](BOARD).0.encoder.00.scale [AXIS_0]INPUT_SCALE net motor.00.pos-fb hm2_[HOSTMOT2](BOARD).0.encoder.00.position => pid.0.feedback net motor.00.pos-fb => axis.0.motor-pos-fb #push copy back to Axis GUI # set PID loop gains from inifile setp pid.0.Pgain [AXIS_0]P setp pid.0.Igain [AXIS_0]I setp pid.0.Dgain [AXIS_0]D setp pid.0.bias [AXIS_0]BIAS setp pid.0.FF0 [AXIS_0]FF0 setp pid.0.FF1 [AXIS_0]FF1 setp pid.0.FF2 [AXIS_0]FF2 setp pid.0.deadband [AXIS_0]DEADBAND setp pid.0.maxoutput [AXIS_0]MAX_OUTPUT # position command signals setp hm2_[HOSTMOT2](BOARD).0.pwmgen.00.output-type 4 #Direction on Out0 and PWM on Out1, "for locked antiphase" setp hm2_[HOSTMOT2](BOARD).0.pwmgen.00.scale [AXIS_0]OUTPUT_SCALE net emcmot.00.pos-cmd axis.0.motor-pos-cmd => pid.0.command net motor.00.command pid.0.output => hm2_[HOSTMOT2](BOARD).0.pwmgen.00.value # ################ # Y [1] Axis # ################ # axis enable chain newsig emcmot.01.enable bit sets emcmot.01.enable FALSE net emcmot.01.enable => pid.1.enable net emcmot.01.enable => hm2_[HOSTMOT2](BOARD).0.pwmgen.01.enable net emcmot.01.enable <= axis.1.amp-enable-out # encoder feedback setp hm2_[HOSTMOT2](BOARD).0.encoder.01.counter-mode 0 setp hm2_[HOSTMOT2](BOARD).0.encoder.01.filter 1 setp hm2_[HOSTMOT2](BOARD).0.encoder.01.index-invert 0 setp hm2_[HOSTMOT2](BOARD).0.encoder.01.index-mask 0 setp hm2_[HOSTMOT2](BOARD).0.encoder.01.index-mask-invert 0 setp hm2_[HOSTMOT2](BOARD).0.encoder.01.scale [AXIS_1]INPUT_SCALE net motor.01.pos-fb hm2_[HOSTMOT2](BOARD).0.encoder.01.position => pid.1.feedback net motor.01.pos-fb => axis.1.motor-pos-fb #push copy back to Axis GUI # set PID loop gains from inifile setp pid.1.Pgain [AXIS_1]P setp pid.1.Igain [AXIS_1]I setp pid.1.Dgain [AXIS_1]D setp pid.1.bias [AXIS_1]BIAS setp pid.1.FF0 [AXIS_1]FF0 setp pid.1.FF1 [AXIS_1]FF1 setp pid.1.FF2 [AXIS_1]FF2 setp pid.1.deadband [AXIS_1]DEADBAND setp pid.1.maxoutput [AXIS_1]MAX_OUTPUT # position command signals setp hm2_[HOSTMOT2](BOARD).0.pwmgen.01.output-type 1 #pwm on pin1, dir on pin2 setp hm2_[HOSTMOT2](BOARD).0.pwmgen.01.scale [AXIS_1]OUTPUT_SCALE net emcmot.01.pos-cmd axis.1.motor-pos-cmd => pid.1.command net motor.01.command pid.1.output => hm2_[HOSTMOT2](BOARD).0.pwmgen.01.value # ################ # Z [2] Axis # ################ # axis enable chain newsig emcmot.02.enable bit sets emcmot.02.enable FALSE net emcmot.02.enable => pid.2.enable net emcmot.02.enable => hm2_[HOSTMOT2](BOARD).0.pwmgen.02.enable net emcmot.02.enable <= axis.2.amp-enable-out # encoder feedback setp hm2_[HOSTMOT2](BOARD).0.encoder.02.counter-mode 0 setp hm2_[HOSTMOT2](BOARD).0.encoder.02.filter 1 setp hm2_[HOSTMOT2](BOARD).0.encoder.02.index-invert 0 setp hm2_[HOSTMOT2](BOARD).0.encoder.02.index-mask 0 setp hm2_[HOSTMOT2](BOARD).0.encoder.02.index-mask-invert 0 setp hm2_[HOSTMOT2](BOARD).0.encoder.02.scale [AXIS_2]INPUT_SCALE net motor.02.pos-fb hm2_[HOSTMOT2](BOARD).0.encoder.02.position => pid.2.feedback net motor.02.pos-fb => axis.2.motor-pos-fb #push copy back to Axis GUI # set PID loop gains from inifile setp pid.2.Pgain [AXIS_2]P setp pid.2.Igain [AXIS_2]I setp pid.2.Dgain [AXIS_2]D setp pid.2.bias [AXIS_2]BIAS setp pid.2.FF0 [AXIS_2]FF0 setp pid.2.FF1 [AXIS_2]FF1 setp pid.2.FF2 [AXIS_2]FF2 setp pid.2.deadband [AXIS_2]DEADBAND setp pid.2.maxoutput [AXIS_2]MAX_OUTPUT # position command signals setp hm2_[HOSTMOT2](BOARD).0.pwmgen.02.output-type 1 #pwm on pin1, dir on pin2 setp hm2_[HOSTMOT2](BOARD).0.pwmgen.02.scale [AXIS_2]OUTPUT_SCALE net emcmot.02.pos-cmd axis.2.motor-pos-cmd => pid.2.command net motor.02.command pid.2.output => hm2_[HOSTMOT2](BOARD).0.pwmgen.02.value # ################################################## # Standard I/O Block - EStop, Etc # ################################################## # create a signal for the estop loopback net estop-loop iocontrol.0.user-enable-out => iocontrol.0.emc-enable-in # create signals for tool loading loopback net tool-prep-loop iocontrol.0.tool-prepare => iocontrol.0.tool-prepared net tool-change-loop iocontrol.0.tool-change => iocontrol.0.tool-changed # # homing # # # In this example, each of the three axes have their own home switch. All # home switches are connected to GPIO 25, though hostmot2 boards generally # have enough GPIO pins to put each axis' home switch on its own pin. # # Each switch is normally open, momentarily closed. When the switch is open, # GPIO 25 floats high (because that is the hostmot2 way). When the switch is # closed, it shorts GPIO 25 to ground. # # EMC expects the value on the .home-sw-in HAL pin to be active high, ie # True when the switch is closed and False when the switch is open. # We get this behavior by linking the GPIO .in_not pin instead of the .in # pin. # net home-switch <= hm2_[HOSTMOT2](BOARD).0.gpio.025.in_not net home-switch => axis.0.home-sw-in net home-switch => axis.1.home-sw-in net home-switch => axis.2.home-sw-in # only the Y servo has an index, X and Z home without using the index net y-index-enable hm2_[HOSTMOT2](BOARD).0.encoder.01.index-enable <=> axis.1.index-enable
5i25.ini
[HOSTMOT2] DRIVER=hm2_pci BOARD=5i25 #CONFIG= No config file needed 5i25" [EMC] # Name of machine, for use with display, etc. MACHINE = Altlas Mill # Debug level, 0 means no messages. See src/emc/nml_int/emcglb.h for others #DEBUG = 0x00000003 #DEBUG = 0x00000007 DEBUG = 0 [DISPLAY] # Name of display program, e.g., tkemc DISPLAY = axis # Cycle time, in seconds, that display will sleep between polls CYCLE_TIME = 0.0500 # Path to help file HELP_FILE = tklinucnc.txt # Initial display setting for position, RELATIVE or MACHINE POSITION_OFFSET = RELATIVE # Initial display setting for position, COMMANDED or ACTUAL POSITION_FEEDBACK = ACTUAL # Highest value that will be allowed for feed override, 1.0 = 100% MAX_FEED_OVERRIDE = 1.5 # Prefix to be used PROGRAM_PREFIX = /home/jmyer/linuxcnc/nc_files # Introductory graphic INTRO_GRAPHIC = linuxcnc.gif INTRO_TIME = 5 [FILTER] PROGRAM_EXTENSION = .png,.gif,.jpg Grayscale Depth Image PROGRAM_EXTENSION = .py Python Script png = image-to-gcode gif = image-to-gcode jpg = image-to-gcode py = python [TASK] # Name of task controller program, e.g., milltask TASK = milltask # Cycle time, in seconds, that task controller will sleep between polls CYCLE_TIME = 0.010 [RS274NGC] # File containing interpreter variables PARAMETER_FILE = hm2-servo.var [EMCMOT] EMCMOT = motmod # Timeout for comm to emcmot, in seconds COMM_TIMEOUT = 1.0 # Interval between tries to emcmot, in seconds COMM_WAIT = 0.010 # Servo task period, in nanoseconds SERVO_PERIOD = 1000000 [HAL] # The run script first uses halcmd to execute any HALFILE # files, and then to execute any individual HALCMD commands. # list of hal config files to run through halcmd # files are executed in the order in which they appear HALFILE = hm2-servo.hal # list of halcmd commands to execute # commands are executed in the order in which they appear #HALCMD = save neta [TRAJ] AXES = 3 # COORDINATES = X Y Z R P W COORDINATES = X Y Z HOME = 0 0 0 0 LINEAR_UNITS = inch ANGULAR_UNITS = degree CYCLE_TIME = 0.010 DEFAULT_VELOCITY = 3.0 MAX_VELOCITY = 4.0 DEFAULT_ACCELERATION = 6.0 MAX_ACCELERATION = 7.0 #!!!!!!!!!!!!! Comment out NO_FORCE_HOMING as soon as connected to actual machine !!!!!!!!!!!!!! NO_FORCE_HOMING = 1 #!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! [AXIS_0] # X Axis TYPE = LINEAR MAX_VELOCITY = 1.0 MAX_ACCELERATION = 4.0 BACKLASH = 0.000 FERROR = 0.010 MIN_FERROR = 0.002 INPUT_SCALE = 81920 OUTPUT_SCALE = -1.000 OUTPUT_OFFSET = 0.0 MAX_OUTPUT = 1.0 MIN_LIMIT = -3.0 MAX_LIMIT = 10.0 HOME = 0.000 HOME_OFFSET = -2.9 HOME_SEARCH_VEL = -0.50 HOME_LATCH_VEL = 0.10 # the X axis servo's encoder does not have an index channel, so we have to home without index HOME_USE_INDEX = NO HOME_IGNORE_LIMITS = YES HOME_SEQUENCE = 1 # PID tuning params DEADBAND = 0.000015 P = 100.0 I = 0.000 D = 0.000 FF0 = 0.000 FF1 = 1.000 FF2 = 0.0 BIAS = 0.000 [AXIS_1] # Y Axis TYPE = LINEAR MAX_VELOCITY = 1.0 MAX_ACCELERATION = 4.0 BACKLASH = 0.000 FERROR = 0.010 MIN_FERROR = 0.002 INPUT_SCALE = -81920 OUTPUT_SCALE = 1.000 OUTPUT_OFFSET = 0.0 MAX_OUTPUT = 1.0 MIN_LIMIT = -3.0 MAX_LIMIT = 10.0 HOME = 0.000 HOME_OFFSET = -2.9 HOME_SEARCH_VEL = -0.50 HOME_LATCH_VEL = 0.10 # the Y axis servo's encoder has an index channel, so we use it to improve the home accuracy HOME_USE_INDEX = YES HOME_IGNORE_LIMITS = YES HOME_SEQUENCE = 1 # PID tuning params DEADBAND = 0.000015 P = 100.0 I = 0.000 D = 0.000 FF0 = 0.000 FF1 = 1.000 FF2 = 0.0 BIAS = 0.000 [AXIS_2] #Z Axis TYPE = LINEAR MAX_VELOCITY = 1.0 MAX_ACCELERATION = 4.0 BACKLASH = 0.000 FERROR = 0.010 MIN_FERROR = 0.002 INPUT_SCALE = 81920 OUTPUT_SCALE = -1.000 OUTPUT_OFFSET = 0.0 MAX_OUTPUT = 1.0 MIN_LIMIT = -3.0 MAX_LIMIT = 3.0 HOME = 0.0 HOME_OFFSET = -2.9 HOME_SEARCH_VEL = -0.50 HOME_LATCH_VEL = 0.10 # the Z axis servo's encoder does not have an index channel, so we have to home without index HOME_USE_INDEX = NO HOME_IGNORE_LIMITS = YES HOME_SEQUENCE = 0 # PID tuning params DEADBAND = 0.000015 P = 100.0 I = 0.000 D = 0.000 FF0 = 0.000 FF1 = 1.000 FF2 = 0.0 BIAS = 0.000 [EMCIO] # Name of IO controller program, e.g., io EMCIO = io # cycle time, in seconds CYCLE_TIME = 0.100 # tool table file TOOL_TABLE = tool.tbl
Time to create page: 0.093 seconds
