Proper methods for a lathe tool changer?
- Thank you received: 4652
12 Apr 2016 23:37 #73203
Replied by andypugh on topic Proper methods for a lathe tool changer?
Sorry, my mistake. They end up in /usr/realtime....../modules/linuxcnc
- Fastest1
13 Apr 2016 00:10 #73204
by Fastest1
Replied by Fastest1 on topic Proper methods for a lathe tool changer?
I did find it there.
I am not able to test it or see anything it does. I am not sure where I would see it or its actions. Nothing is different when I open LCNC from my shortcut.
Either way there was some success today. For that I thank you.
13 Apr 2016 11:56 #73222
Nothing will be different, you haven't changed anything yet....
You can try running the new demo config. That should show signs of running the toolchanger as a simulation, but it won't run your machine.
You need to look at how the toolchanger component is set up in the demo config and modify that to suit your machine config.
Time to create page: 0.120 seconds
