Starting over
10 years 1 month ago #80678 by Patrick Obrien
Starting over was created by Patrick Obrien
I purchased a three axis kit with 4 steppers, 4' by 8'. Two on the X, one on the Y and the Z. I have it together and am installing limit switches on all the axis extremes. I don't have a router yet.
I bought a Mesa 5i25 and G540 before I'd thought it though.Linux I know but learning Linuxcnc, the Geko and the Mesa was a bit more than I expected. Not knocking them but I've since read of a lot of other frustrated guys fighting that config and having problems getting the HAL and INI worked out, especially on a 4-axis machine with a lot of switches.
I am not married to either the Mesa or the Geko. I would like to discover and use the hardware which has mature config files and best support within the forum. I realize I could get my existing hardware working after I do endless edits and hammer the forum with questions while you teach me esoteric HAL programming but I'd rather swim with rather than against the tide.
Which config is the most robust and best supported within the group? What hardware does it expect to interface too?
10 years 1 month ago - 10 years 1 month ago #80685 by andypugh
Replied by andypugh on topic Starting over
Patrick Obrien wrote: Which config is the most robust and best supported within the group? What hardware does it expect to interface too?
Probably parallel port and G540.
And that might be the way to go. Set up for a G540 with stepconf and the parallel port. Then swap the parallel port for the 5i25 when you feel more comfortable with the rest of the system.
You don't have a 4-axis machine, you have a 3-axis machine. You can just connect X-step and X-dir to two pins each on the parport in stepconf.
Eventually I would suggest installing the 5i25 and upgrading LinuxCNC to 2.8 where support for systems with more than one motor per axis are significantly better supported.
Or, just hammer the forum with questions, it helps us feel useful :-)
Last edit: 10 years 1 month ago by andypugh.
10 years 1 month ago #80688 by Patrick Obrien
Replied by Patrick Obrien on topic Starting over
I thought about the wiring shortcut but then remembered how many ways I could regret that. Just me.
Ok question one. I don't recall a global for the interface,something like
interface = parport
# interface = 5i25
so there must be a config rewrite. I looked through the forum but didn't find a guide.. If there is a form reference I missed, let me know.
10 years 1 month ago #80690 by andypugh
Have you tried running PNCConf?
10 years 1 month ago #80693 by Patrick Obrien
Not in a while. I recall it wanted an 5i25 with another mesa card. G540 was not an option.
10 years 1 month ago - 10 years 1 month ago #80728 by BigJohnT
Replied by BigJohnT on topic Starting over
Is the 5i25 flashed for the G540?
www.mesaus.com/info/mesaflash.html
The biggest problem people have are with the charge pump on the G540 which can be turned off.
If you have a lot of I/O you might consider a 7i76 or a standard breakout board attached to P2.
JT
Last edit: 10 years 1 month ago by BigJohnT.
