Starting over
12 Oct 2016 21:34 #81591 by andypugh
Replied by andypugh on topic Starting over
I realize I could get my existing hardware working after I do endless edits and hammer the forum with questions while you teach me esoteric HAL programming but I'd rather swim with rather than against the tide.
How are you enjoying the journey upstream?
It just occurred to me that we haven't really done much to prove that it is easy. But I am hoping that you are at least enjoying the process?
See it as like skid-pan training. It's not an easy way to drive a car, but you learn a lot about the car.
13 Oct 2016 10:16 #81598 by blacksmith
Replied by blacksmith on topic Starting over
If this is for a G540 I would set the steplength on all axis to 2500 minimum (1000 will not work reliably)
If the axis are swapped that suggests that you are not using the proper FPGA configuration
It is a 540 and I guess the readhmid file above doesn't reference that I uploaded the 5i25_g540x2.bit file. I'll try those steplength values.
13 Oct 2016 10:30 #81599 by blacksmith
I watched a guy drive a new shiny red Lotus a little too far under a guard rail shattering the front windscreen into smithereens. His rage at his ineptness was close to seismic - I'm not quite there yet.
13 Oct 2016 16:16 - 13 Oct 2016 16:28 #81613 by Patrick Obrien
Replied by Patrick Obrien on topic Starting over
sudo mesaflash --device 5i25 --write 5i25_g540x2.bit
sudo mesaflash --device 5i25 --reload
The enclosure is the mesaflash reflash - no issues there, I just enclosed it for illustration - assuming there is not a version issue.
On steplength, 2500 does change a few things; "X" moves the Y axis, "Y" moves Z and "Z" moves X2 (aka A). This is a G540 so miswiring the drivers is almost idiot proof.
Last edit: 13 Oct 2016 16:28 by Patrick Obrien.
13 Oct 2016 16:29 #81615 by PCW
Replied by PCW on topic Starting over
Right, so the errors are in the hal axis --> stepgen mapping
The G540 FPGA config is straight forward (stepgens 0,1,2,3 map into G540 axis X,Y,Z,A)
13 Oct 2016 16:51 #81618 by Patrick Obrien
How can I verify I have the correct 5i25_g540x2.bit file?
cksum 5i25_g540x2.bit
3087903293 340704 5i25_g540x2.bit
sum 5i25_g540x2.bit
17348 333
13 Oct 2016 17:50 - 13 Oct 2016 17:51 #81621 by PCW
AFAIK, there are no incorrect 5i25_g540x2.bit bitfiles
( and your mesaflash readhmid listing shows the expected G540 compatible pinout )
As I said, the joint mapping error is in the HAL file
Last edit: 13 Oct 2016 17:51 by PCW.
14 Oct 2016 00:16 #81628 by Patrick Obrien
Thanks for that. I assumed since PNCCONF generated the file it was correct.
I did a simple test, I generated a XYZ config using PNCCONF and the axis work, X moves X ,etc. This tells me you are correct, the hal is off - it looks like a PNCCONF bug but probably a newbie snafu,
I did a diff of the two files, the XXYZ and the XYZ.
Using the XXYZ fundamentally shift the stepgen's. See the diff output enclosed.
Here is a sample:
setp hm2_5i25.0.stepgen.02.dirsetup [AXIS_1]DIRSETUP | setp hm2_5i25.0.stepgen.01.dirsetup [AXIS_1]DIRSETUP
14 Oct 2016 00:30 #81629 by PCW
Are you saying the pncconf config is in error (does not match what you selected)?
Normally a XYZ config to maps like this
X => 0
Y => 1
Z => 2
And I would expect a XXYZ config to map like this
Xa => 0
Xb => 1
Y => 2
Z => 3
but of course the mapping of axis to stepgens is arbitrary but the created hal file
should match what you select in pncconf
14 Oct 2016 15:12 #81644 by Patrick Obrien
Xa => 0
Xb => 1
Y => 2
Z => 3
Ok if that is the case (Y and Z shift one plus) then the HAL is correct. Ok more digging.
Time to create page: 0.207 seconds
