Starting over
23 Sep 2016 15:57 #80833 by Patrick Obrien
Replied by Patrick Obrien on topic Starting over
Eventually I would suggest installing the 5i25 and upgrading LinuxCNC to 2.8 where support for systems with more than one motor per axis are significantly better supported.
Is there an iso for 2.8?
23 Sep 2016 22:52 #80839 by BigJohnT
Replied by BigJohnT on topic Starting over
buildbot.linuxcnc.org/
You just have to change a couple of things in the Synaptic Package Manager.
JT
02 Oct 2016 23:37 #81159 by Patrick Obrien
This setup should be really very close:
Since Launch test panel did't work I tried Test/Tune Axis. I ran into a snag with pncconf @ test/tune. I suspect it is my error but I am not that far into pncconf.config yet. Any hints?
03 Oct 2016 09:24 #81172 by andypugh
Replied by andypugh on topic Starting over
I think that error is an actual bug.
github.com/LinuxCNC/linuxcnc/issues/159
Try skipping the test/tune part, then worry about it if the axes don't actually move with the final config.
03 Oct 2016 21:43 #81196 by Patrick Obrien
Is there an external Test/Tune Axis app?
03 Oct 2016 21:57 #81197 by andypugh
There are ways. With a stepper system the axes will either work with the final LinuxCNC config, or they wont.
05 Oct 2016 17:51 - 05 Oct 2016 17:54 #81262 by Patrick Obrien
Perhaps I'll use stepconf, test the wiring, tune it a bit and transfer the values to pncconf. Unless the same bug exists there.
Last edit: 05 Oct 2016 17:54 by Patrick Obrien. Reason: add
07 Oct 2016 12:28 #81335 by andypugh
That sounds like a reasonable approach. It reduces the number of unknowns.
11 Oct 2016 21:17 #81565 by Patrick Obrien
The setup works on the parallel port but the same basic values are incorrect in the pncconf version. My pncconf assignments match the suggested configuration.
In this version, X & Z do nothing but Y moves the spindle up and down. Please review the enclosed configuration files and tell me where I am going wrong.
12 Oct 2016 20:55 #81590 by PCW
Replied by PCW on topic Starting over
If this is for a G540 I would set the steplength on all axis to 2500 minimum (1000 will not work reliably)
If the axis are swapped that suggests that you are not using the proper FPGA configuration
To write the proper FPGA configuration you would:
sudo mesaflash --device 5i25 --write 5i25_g540x2.bit
sudo mesaflash --device 5i25 --reload
and to verify pinout you would:
sudo mesaflash --device 5i25 --readhmid
Time to create page: 0.260 seconds
