- Thank you received: 4
Gantry machine progress
9 years 2 months ago #96993
by Yannis
Replied by Yannis on topic Gantry machine progres
hi
i try to home the machine manual
to do that i zero all the values in the home sequence in th INI file
i zero the X and Y everything is OK
when i try to zero the Z i have the first error for Joint3(why that happens in manual Z homing?)
when i try to zero the C i have the second error Joint3(the C is configured as 4 Joint)
any suggestion where to look for this settings?
9 years 2 months ago #97126
Replied by andypugh on topic Gantry machine progres
Do the Z and C axes jog properly? The problem might be that the encoders and the PID disagree about which way is left and which is right.
9 years 2 months ago #97345
by Yannis
Hi
i will check that Monday morning
thanks
thanks
9 years 2 months ago - 9 years 2 months ago #97359
by Yannis
Hi
i manage to home the machine and after that thinks are going better but still have some problems
after i home the machine the x axis can jog until -0.10 and after that stops and that is great because it is the -x limit
and after that can jog only to the positive area:laugh:
Y axis is stop when it reach the -0.10 but after that pop up this error
i look in the INI file but i can not understand the problem
any suggestions??
thanks
any suggestions??
thanks
Last edit: 9 years 2 months ago by Yannis.
9 years 2 months ago #97368
The misconfiguration may be that you have two [AXIS_Y] sections in the INI, and the first one (which is what the system will find) does not contain any limits.
The machine has definitely gone past the limits as far as LinuxCNC is concerned. Is this physically true?
It might be that the acceleration limits that LinuxCNC is using do not match the real limits, and so so the axis moved further than LinuxCNC commanded it to.
9 years 2 months ago #97387
by Yannis
Hi
i have check and the INI file of the Y and the are there
# Joint 1
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 5000
MAX_ACCELERATION = 250.0
P = 1.5
I = 0
D = 0
FF0 = 0
FF1 = 0.014
FF2 = 0
BIAS = 0
DEADBAND = 0.001
MAX_OUTPUT = 10
ENCODER_SCALE = 800
OUTPUT_SCALE = 10
OUTPUT_MIN_LIMIT = -10
OUTPUT_MAX_LIMIT = 10
MIN_LIMIT = -0.01
MAX_LIMIT = 1500.0
HOME_OFFSET = 5.0
HOME = 0
HOME_SEQUENCE = -1
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 0
HOME_USE_INDEX = no
HOME_IGNORE_LIMITS = yes
[AXIS_Y]
MAX_VELOCITY = 5000
# ---y1---
#Joint 2
[JOINT_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 5000
P = 1.5
I = 0
D = 0
FF0 = 0
FF1 = 0.014
FF2 = 0
BIAS = 0
DEADBAND = 0.001
MAX_OUTPUT = 10
ENCODER_SCALE = 800
OUTPUT_SCALE = 10
MIN_LIMIT = -0.01
MAX_LIMIT = 1500.0
HOME_OFFSET = 5.0
HOME = 0
HOME_SEQUENCE = -1
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 0
HOME_USE_INDEX = no
# Axis Y
[AXIS_Y]
MAX_VELOCITY = 5000
MIN_LIMIT = -0.01
MAX_LIMIT = 1500.0
and are the same
# Joint 1
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 5000
P = 1.5
I = 0
D = 0
FF0 = 0
FF1 = 0.014
FF2 = 0
BIAS = 0
DEADBAND = 0.001
MAX_OUTPUT = 10
ENCODER_SCALE = 800
OUTPUT_SCALE = 10
MIN_LIMIT = -0.01
MAX_LIMIT = 1500.0
HOME_OFFSET = 5.0
HOME = 0
HOME_SEQUENCE = -1
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 0
HOME_USE_INDEX = no
[AXIS_Y]
MAX_VELOCITY = 5000
# ---y1---
#Joint 2
[JOINT_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 5000
P = 1.5
I = 0
D = 0
FF0 = 0
FF1 = 0.014
FF2 = 0
BIAS = 0
DEADBAND = 0.001
MAX_OUTPUT = 10
ENCODER_SCALE = 800
OUTPUT_SCALE = 10
MIN_LIMIT = -0.01
MAX_LIMIT = 1500.0
HOME_OFFSET = 5.0
HOME = 0
HOME_SEQUENCE = -1
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 0
HOME_USE_INDEX = no
# Axis Y
[AXIS_Y]
MAX_VELOCITY = 5000
MIN_LIMIT = -0.01
MAX_LIMIT = 1500.0
and are the same
Time to create page: 0.290 seconds
