- Thank you received: 4
Gantry machine progress
9 years 3 months ago #96880
by Yannis
Replied by Yannis on topic Gantry machine progres
#----y1---
setp pid.y1.Pgain [JOINT_1]P
setp pid.y1.Igain [JOINT_1]I
setp pid.y1.Dgain [JOINT_1]D
setp pid.y1.bias [JOINT_1]BIAS
setp pid.y1.FF0 [JOINT_1]FF0
setp pid.y1.FF1 [JOINT_1]FF1
setp pid.y1.FF2 [JOINT_1]FF2
setp pid.y1.deadband [JOINT_1]DEADBAND
setp pid.y1.maxoutput [JOINT_1]MAX_OUTPUT
setp pid.y1.error-previous-target true
net y1-index-enable <=> pid.y1.index-enable
net y1-enable => pid.y1.enable
net y1-pos-cmd => pid.y1.command
net y1-vel-cmd => pid.y1.command-deriv
net y1-pos-fb => pid.y1.feedback
net y1-output => pid.y1.output
# ---PWM Generator signals/setup---
setp hm2_5i25.0.7i77.0.1.analogout2-scalemax [JOINT_2]OUTPUT_SCALE
setp hm2_5i25.0.7i77.0.1.analogout2-minlim [JOINT_2]OUTPUT_MIN_LIMIT
setp hm2_5i25.0.7i77.0.1.analogout2-maxlim [JOINT_2]OUTPUT_MAX_LIMIT
net y1-output => hm2_5i25.0.7i77.0.1.analogout2
net y1-pos-cmd joint.2.motor-pos-cmd
net y1-enable joint.2.amp-enable-out
setp hm2_5i25.0.encoder.01.counter-mode 0
setp hm2_5i25.0.encoder.01.filter 1
setp hm2_5i25.0.encoder.01.index-invert 0
setp hm2_5i25.0.encoder.01.index-mask 0
setp hm2_5i25.0.encoder.01.index-mask-invert 0
setp hm2_5i25.0.encoder.01.scale [JOINT_2]ENCODER_SCALE
net y1-pos-fb <= hm2_5i25.0.encoder.02.position
net y1-vel-fb <= hm2_5i25.0.encoder.02.velocity
net y1-pos-fb => joint.2.motor-pos-fb
net y1-index-enable joint.2.index-enable <=> hm2_5i25.0.encoder.02.index-enable
net y1-pos-rawcounts <= hm2_5i25.0.encoder.02.rawcounts
# ---setup home / limit switch signals---
net y1-home-sw => joint.2.home-sw-in
net y1-neg-limit => joint.2.neg-lim-sw-in
net y1-pos-limit => joint.2.pos-lim-sw-in
is this the right values?
9 years 3 months ago #96888
Replied by andypugh on topic Gantry machine progres
No, you are still over-writing the values for encoder.01 in the Y1 section rather than setting the values for encoder.02
9 years 3 months ago #96889
by Yannis
if you do thinks with out now what you are doing this is what happens
# JOINT Y0
setp pid.y0.Pgain [JOINT_1]P
setp pid.y0.Igain [JOINT_1]I
setp pid.y0.Dgain [JOINT_1]D
setp pid.y0.bias [JOINT_1]BIAS
setp pid.y0.FF0 [JOINT_1]FF0
setp pid.y0.FF1 [JOINT_1]FF1
setp pid.y0.FF2 [JOINT_1]FF2
setp pid.y0.deadband [JOINT_1]DEADBAND
setp pid.y0.maxoutput [JOINT_1]MAX_OUTPUT
setp pid.y0.error-previous-target true
net y0-index-enable <=> pid.y0.index-enable
net y0-enable => pid.y0.enable
net y0-pos-cmd => pid.y0.command
net y0-vel-cmd => pid.y0.command-deriv
net y0-pos-fb => pid.y0.feedback
net y0-output => pid.y0.output
setp hm2_5i25.0.7i77.0.1.analogout1-scalemax [JOINT_1]OUTPUT_SCALE
setp hm2_5i25.0.7i77.0.1.analogout1-minlim [JOINT_1]OUTPUT_MIN_LIMIT
setp hm2_5i25.0.7i77.0.1.analogout1-maxlim [JOINT_1]OUTPUT_MAX_LIMIT
net y0-output => hm2_5i25.0.7i77.0.1.analogout1
net y0-pos-cmd joint.1.motor-pos-cmd
net y0-enable joint.1.amp-enable-out
setp hm2_5i25.0.encoder.01.scale [JOINT_1]ENCODER_SCALE
net y0-pos-fb <= hm2_5i25.0.encoder.01.position
net y0-vel-fb <= hm2_5i25.0.encoder.01.velocity
net y0-pos-fb => joint.1.motor-pos-fb
net y0-index-enable joint.1.index-enable <=> hm2_5i25.0.encoder.01.index-enable
net y0-pos-rawcounts <= hm2_5i25.0.encoder.01.rawcounts
net y0-home-sw => joint.1.home-sw-in
net y0-neg-limit => joint.1.neg-lim-sw-in
net y0-pos-limit => joint.1.pos-lim-sw-in
#----y1---
setp hm2_5i25.0.encoder.02.counter-mode 0
setp hm2_5i25.0.encoder.02.filter 1
setp hm2_5i25.0.encoder.02.index-invert 0
setp hm2_5i25.0.encoder.02.index-mask 0
setp hm2_5i25.0.encoder.02.index-mask-invert 0
setp hm2_5i25.0.encoder.02.scale [JOINT_2]ENCODER_SCALE
is this near to what i try to fix?
# JOINT Y0
#----y1---
9 years 3 months ago #96890
This looks wrong too:
9 years 3 months ago - 9 years 3 months ago #96891
by Yannis
i have to change the Joint 1 to Joint 2 right?
Last edit: 9 years 3 months ago by Yannis.
9 years 3 months ago #96893
by Yannis
sorry and the analog1 to analog2
Time to create page: 0.082 seconds
