Gantry machine progress
9 years 3 months ago #96894 by andypugh
Replied by andypugh on topic Gantry machine progres
No, the problem is the analogout1.
[JOINT_1] might be correct, if you want to share settings.
(But you really do need to make a decision about that, and be consistent)
9 years 3 months ago #96898 by Yannis
Replied by Yannis on topic Gantry machine progres
ok
i change the values an it is the first time i have both y0 and y1 enable and stand still
i can not home the machine because of a problem with the z axis break
when i try to jog the y axis only the y0 motor is rotating, the acceleration on the display is moving, but not the y axis value
where to look for this
9 years 2 months ago #96922 by andypugh
Yannis wrote: ok
Is the display showing 1234 or XYZ ?
You won't be able to jog the gantry until you are in "World Mode" (XYZ) and you won't be able to go to that mode until you are homed.
9 years 2 months ago #96960 by Yannis
in the display is X Y Z C (for the c i modified the INI file as you suggest)
Yannis wrote: how can i change the A axis letter with C at the display of the axis
thanks for the help
andypugh This is configured by a combination of the [DISPLAY]COORDINATES and [TRAJ]COORDINATES INI file settings
i read that to change from X Y Z C to 12345 there is the $ in the view section
9 years 2 months ago #96964 by Yannis
update
after i change the TRAJECTORY of the INI file from X Y Z C to X Y Y Z C the jog goes like this
up key Y0 +(values don't change on the display)
down key Y0 -(values don't change on the display)
left key X+
right key X-
page up Y1+ (values change on the display)
page down Y1-(values change on the display)
i wonder where is the Z+ Z-
also i wonder how to configure keys on the keyboard for the C+ C- jogging
9 years 2 months ago #96966 by Yannis
File Name: my_LinuxCN...8-03.ini
File Size:5.13 KB
File Name: my_LinuxCN...8-03.hal
File Size:14.31 KB
latest INI and HAL file
Time to create page: 0.283 seconds
