Gantry machine progress
9 years 3 months ago #96763
Yes.
Replied by andypugh on topic Gantry machine progres
Yannis wrote: HOME_SEQUENCE = 1 in Joints 0,3,4
and
HOME_SEQUENCE = -1 in Joints 1,2??
Yes.
9 years 3 months ago #96766
by Yannis
Replied by Yannis on topic Gantry machine progres
when i try to calibrate the joint 2 i notice that the screen is different from the other Joints
is this normal?
is this normal?
9 years 3 months ago #96767
by Yannis
9 years 3 months ago #96769
If you are sharing the PID values between joints 1 and 2, then yes.
The following user(s) said Thank You: Yannis
9 years 3 months ago #96771
by Yannis
when i try to enable the linux cnc f2 i have a Joint2 error
in Joint 1 and Joint 2 i have identical bru 200 motors and drivers with exactly the same P>I>D settings
what could cause this??
9 years 3 months ago #96772
Do both motors need to turn in the same direction? Most gantries need the motors to turn in opposite directions.
You may need to reverse Y2. (make the encoder scales and analogout-scale both the negative of their current values).
Time to create page: 0.336 seconds
