Gantry machine progress
9 years 3 months ago #96727 by Yannis
Replied by Yannis on topic Gantry machine progres
Hi
the A display issue solved
the problem now is to connect the y1 motor to the mesa board i try to copy the y (joint1) and edit the values
with no success
what i missing here?
9 years 3 months ago - 9 years 3 months ago #96728 by Yannis
File Name: my_LinuxCN...7-31.hal
File Size:14.2 KB
Last edit: 9 years 3 months ago by Yannis.
9 years 3 months ago #96729 by rodw
Replied by rodw on topic Gantry machine progres
This appears identical to joint 1
# ---PWM Generator signals/setup--- setp hm2_5i25.0.7i77.0.1.analogout1-scalemax [JOINT_2]OUTPUT_SCALE setp hm2_5i25.0.7i77.0.1.analogout1-minlim [JOINT_2]OUTPUT_MIN_LIMIT setp hm2_5i25.0.7i77.0.1.analogout1-maxlim [JOINT_2]OUTPUT_MAX_LIMIT
I don't know your hardware but maybe it is
hm2_5i25.0.7i77.0.1.analogout2-******
9 years 3 months ago #96730 by Yannis
hi
in hardware you re fair to the mesa boards i use 5i25 and 5i77
9 years 3 months ago #96731 by Yannis
i make this changes but i still
File Name: my_LinuxCN...31-2.hal
File Size:14.2 KB
have error(how can i post the error message i try to copu it with no success
9 years 3 months ago - 9 years 3 months ago #96732 by andypugh
Replied by andypugh on topic Gantry machine progres
Yannis wrote: Hi
with no success
You are close, but you need to edit things a bit more.
The second motor needs its own PID component. In the file you showed us the Y1 axis is trying to link to the Y PID.
You can, if you want, use the same PID gains for both sides of the gantry. This is likely to be correct and means you can't mis-match them.
I suggest, for clarity:
... loadrt pid names=pid.x,pid.y0,pid.y1,pid.z,pid.s ... #******************* # JOINT Y0 #******************* setp pid.y0.Pgain [JOINT_1]P setp pid.y0.Igain [JOINT_1]I ... # ---PWM Generator signals/setup--- setp hm2_5i25.0.7i77.0.1.analogout1-scalemax [JOINT_1]OUTPUT_SCALE setp hm2_5i25.0.7i77.0.1.analogout1-minlim [JOINT_1]OUTPUT_MIN_LIMIT setp hm2_5i25.0.7i77.0.1.analogout1-maxlim [JOINT_1]OUTPUT_MAX_LIMIT net y0-output => hm2_5i25.0.7i77.0.1.analogout1 net y0-pos-cmd joint.1.motor-pos-cmd net y0-enable joint.1.amp-enable-out #******************* # JOINT Y1 #******************* setp pid.y1.Pgain [JOINT_1]P setp pid.y1.Igain [JOINT_1]I ... net y1-index-enable <=> pid.y1.index-enable net y1-enable => pid.y1.enable net y1-pos-cmd => pid.y1.command net y1-vel-cmd => pid.y1.command-deriv net y1-pos-fb => pid.y1.feedback net y1-output => pid.y1.output # ---PWM Generator signals/setup--- setp hm2_5i25.0.7i77.0.1.analogout2-scalemax [JOINT_1]OUTPUT_SCALE setp hm2_5i25.0.7i77.0.1.analogout2-minlim [JOINT_1]OUTPUT_MIN_LIMIT setp hm2_5i25.0.7i77.0.1.analogout2-maxlim [JOINT_1]OUTPUT_MAX_LIMIT net y1-output => hm2_5i25.0.7i77.0.1.analogout2 net y1-pos-cmd joint.2.motor-pos-cmd net y1-enable joint.2.amp-enable-out
Last edit: 9 years 3 months ago by andypugh.
Time to create page: 0.063 seconds
