LinuxCNC S-Curve Accelerations
1 year 6 months ago #327378 by PCW
Replied by PCW on topic LinuxCNC S-Curve Accelerations
Indeed if you set acceleration to 200, the scurve max acceleration will be 400 at inflection point.
Exceeding your max acc off 240.
I get the same error even if all accelerations are set to 100 in the ini file
The following user(s) said Thank You: Lcvette, Grotius, zmrdko
1 year 6 months ago #327419 by Grotius
@Pcw,
Thanks for reporting this.  For now i will keep this in mind, and will test this later on.
The [TRAJ] section is responsible for setting the planners max-acceleration values.
The planner doesn't look at the individual joint max acceleration values. Maybe that is causing trouble.
@All,
Ok, for the cia-402 component i made a home sequence intrusion in the homemod.so component.
It basicly enables external homing, and not triggering following error etc during this procedure.
All is done with a few hal pins.
When using the servo's internal home sequence the lcnc home sequence can now be done by a connecting a few hal pins.
For each joint, you can activate the cia-402 home sequence.
In this way, a non cia-axis, can be homed by lcnc's original method as usual.
1. You can set pin for enabling the cia-402 internal servo drive home sequence.
Set this flag "setp" in the .hal file after you load the cia component for example.
2. The cia-402 recieves a home command from homemod.so
Connect the cia-402 home command pin (input) -> homemod home-drive (output)
3. The cia-402 servo pos feebback is passed to the homemod.so when the servo is homing and changing position.
Connect the cia-402 pos-feedbak (output) -> homemod.so pos-fb
4. When the cia-402 drive is homed, it updates a flag in homemod.so wich set homed = 1.
Connect the cia-402 is homed flag (output) -> homemod.so drive-is-homed.
libhome
source code intrusion
Sinds i have no cia hardware, i tested this ok in a linuxcnc simulation config.
The following user(s) said Thank You: Lcvette, besriworld, zmrdko
1 year 6 months ago #327428 by PCW
I did set the acceleration in the TRAJ section, it does affect the acceleration
but the scaling seems not to be correct. The Acceleration/Velocity bounds are important
since they are per joint physical limitations.
(sorry if I am getting out the sandpaper when construction is at the chainsaw stage)
It is great so see  a jerk limited profile working with LinuxCNC as it fixes the inevitable
following error at the start/end of motion due to the impossibility of having instant force
application in any real drive system.
The following user(s) said Thank You: akb1212, tommylight, Lcvette, besriworld, zmrdko
1 year 5 months ago #327868 by Grotius
Hi Pcw,
Can you try once more with Mesa?
In the repository :
git pull
cd cmake
./build_cmake
Added pins to monitor at runtime:
tpmod.hal_component_max_cycle_time_ns
tpmod.hal_component_max_cycle_time_scurve_ns
Param to start with, also influences max acc :
tpmod.hal_max_jerk = 5
Then the above pins must stay below ~50000 nanosec at runtime.
Everything above 1000000 ns is bad.
We have now 3 configs wich run scurve. 1 is in Slowakia and runs like a rocket on delta servo's.
My ethercat steppers run, but not optimal as my desktop pc has bad latency. Base thread & ethercat apptime = 80000
Another machine is in Italy and had bad .hal config wich broke the scurve at runtime. Now that is fixed, it run's.
The following user(s) said Thank You: besriworld, zmrdko
1 year 5 months ago #327870 by PCW
Will test today or tomorrow.
The following user(s) said Thank You: besriworld, Grotius, zmrdko
1 year 5 months ago #327874 by Grotius
Hi Pcw,
Thanks for your fast responce.
We have an issue on codeberg. I invested today to find why the scurve some times breaks. We then see a
vertical line in the plot of tpmod.curvel.
The curve kind of starting from vel=0 again. Jumping etc.
It seems if my base thread is set to 50000 (too fast),
the scurve lib is not able to finish the algo anymore. Resulting in strange behaviour.
Like a sqrt() function taking about 1 ms to complete, wich is absolulutely madness.
Now if i set the base thread to 80000. Everything goes fine.
So i thought, better you know this also.
The guy in italy had 6 axis ethercat running, very difficult .hal setup, constantly breaking the scurve every move,
even without clothoids.
So now i helped him with remote desktop for hours. And now with a simple config he runs ok. We don't know
his cause exactly. But we are happy the problem is gone now.
The following user(s) said Thank You: tivoi, besriworld, zmrdko
Time to create page: 0.223 seconds
