- Thank you received: 4153
The only time this is necessary is during internal homing (if used). During homing, motion is happening that Linuxcnc does not know about so it generates a following error if this is not done.Hi,
Can we test the cia-402 and shortcut linuxcnc pos-cmd to pos-feedback so
there is no ferror in linuxcnc that can trigger a motion stop?
Or test it by hooking the cia-402 to a stepgen or pid without closed loop feedback.
cia402 defines pins to set velocity and acceleration while homing. 0x6099 and 0x609a
hi
in my last test there was no following error on gcode running, the problem was the very low acceleration.
following errors appears on homing procedure
